idle?
Old Aug 27, 2014 | 06:27 PM
widejd's Avatar
widejd
Default idle?
2013 wide glide..I was riding the other day and had been on the interstate for about 45 min, when I turned off and went into town and was stopping at a stop light the bike continued to idle at around 1700rpm. I let out on the clutch a little with the brake on to bog it down and then it stayed at the correct idle (950-1000). This has happened a couple of times. Any ideas on what this could be? It runs great and is currently using the Power Vision map given to me by Fuel Moto. Thanks
Old Aug 27, 2014 | 06:49 PM
RANGER73's Avatar
RANGER73
If it were a carb, I'd say the cable, linkage or throttle's sticking.
Old Aug 27, 2014 | 07:06 PM
slyedog's Avatar
slyedog
Spray a little air intake cleaner in the iacv port or check the iac steps in your tune. My sporty liked to do that but my Dyna never has. Spray did it for sporty. Also check your friction screw under throttle grip and loosen up a tad.
Old Aug 27, 2014 | 07:14 PM
DJY's Avatar
DJY
Mine does the same thing. Has for awhile. It goes down after a few seconds after being completely stopped. Doesn't worry me unless it gets worse.
Old Aug 27, 2014 | 07:19 PM
bdtaylor1979's Avatar
bdtaylor1979
Same here.
Old Aug 27, 2014 | 09:19 PM
07_Dyna's Avatar
07_Dyna
I might suggest a little Lucas, Sea Foam or your favorite concoction... Mine seems to be prone to gum up in the injection department?
Old Aug 28, 2014 | 11:28 AM
spdrcrjl's Avatar
spdrcrjl
It's probably the IAC motor.
Buddy Shagmore
Feb 20, 2018 07:55 AM
tar_snake
EVO
Aug 26, 2017 07:29 AM
JHummel89
Shovelhead
Jun 10, 2012 12:44 PM
kdemrich
Jan 25, 2011 09:59 PM
