Air Cleaner
Old Sep 9, 2015 | 02:04 AM
o0smitters0o's Avatar
o0smitters0o
Originally Posted by jmb79
All the better known high capacity air cleaners will flow more air than your engine can use, even if you've had engine work done. Thus, the choice of which a/c to buy really comes down to looks, and to a lesser degree, ergonomics. Some air cleaners are thicker than others and may hit your right knee, still others, like the heavy breather, turn forward and provide more knee room.
Can an air filter that allows more air than the bike use be a problem? I went to Performance Machine Max HP had dyno'd, now it's running hot, getting decel pops and exhaust valves are white from heat. Do you think bad Dyno or could air filter contribute to that? Acting like if I had air intake leak because so much air is going in?
Old Sep 9, 2015 | 02:21 AM
AdamM's Avatar
AdamM
Old thread, but a good tune should correct that. You adding an a/c is letting more air in, now you need more fuel to compensate. HD runs lean from the factory as is, doing an incomplete stage one just makes it worse
Old Sep 9, 2015 | 05:18 AM
Warp Factor's Avatar
Warp Factor
They should have sorted that stuff out during the dyno tune.
Most of the time, the air filter won't be changing air flow anyway. Except at wide open throttle (or close to wide open throttle), it's the throttle blade that restricts airflow, not the air cleaner.
Old Sep 9, 2015 | 06:35 AM
Iron obsessed's Avatar
Iron obsessed
Originally Posted by CaptainHook
Just looking for some opinions on whats a good air cleaner for the dyna?
Looking into a screaming eagle heavy breather or perhaps s&s teardrop...
Looking for best of both worlds performance and looks
S&S dual cone! Acts like a ram air...looks sweet, have one on my FXDL
Old Sep 9, 2015 | 12:03 PM
freebaggin's Avatar
freebaggin
S&S Stealth, works great for me so far. I have a rain sock for it but I only used it once, rode in rain a few times without the sock and no issues.
Old Sep 10, 2015 | 09:30 AM
boro's Avatar
boro
Default more oiling?
Does the filter being exposed cause it to require more frequent oiling? I had one on a sportster that became dull and dry looking really fast.
Old Sep 10, 2015 | 10:50 AM
Warp Factor
Yes. Driving in rain will wash some of the oil through to the engine, taking some of the trapped dirt along with it.
Wolfman Mucklehardy
Jun 12, 2014 02:06 PM
chunks
Jun 17, 2009 01:31 PM
ncbeast
Feb 15, 2009 08:35 PM
Kilroy
Aug 10, 2008 10:22 AM
kjtoys
Mar 29, 2008 04:43 PM
