FXDF Headlight Bulb Replacement
Old Sep 10, 2014 | 02:25 PM
HAP76's Avatar
HAP76
Default FXDF Headlight Bulb Replacement
OK, this should be easy, but I cant remove the bulb from the connector.
I had no problem removing the trim ring or separating the bulb and headlamp connector from the back of the headlamp lens, but I can't figure out how to separate the bulb from the connector. Looks like it should pull straight out but it doesn't seem to want to. Replacement bulb has three straight pins on the back so I can tell it should pull straight out. There is a red tab on the connector that slides in and out. I have tried it in both positions (in and out), but doesn't seem to make a difference.
Anyone else run into this?
Old Sep 10, 2014 | 02:48 PM
gadianton3's Avatar
gadianton3
Default push in then pull
I haven't done one of those specifically. But I run into them all the time in the 4 wheeled world. A lot of times it helps to push down on the connector while sliding the red tab then pull. Not really sure how else to describe it?
Old Sep 11, 2014 | 09:18 AM
HAP76's Avatar
HAP76
Thanks for the advice gadianton. Just to clarify, when you say to "push down on the connector", do you mean push it towards the bulb?
Borderman
Dyna Glide Pictures
Sep 10, 2014 12:10 PM
USMC7236
Jun 30, 2013 11:40 AM
anubisss
Sep 13, 2011 03:22 PM
gunner11
Feb 14, 2010 01:55 AM
JBA111
Aug 21, 2006 11:44 PM
