Headlamp bulb help
Old May 27, 2008 | 09:24 AM
USMC7236's Avatar
USMC7236
Default Headlamp bulb help
Anyone changed the headlamp bulb on a 2008 Dyna (FXDB)? I've come across a couple issues. Searched here a bunch, and I have a service manual, no help either place.
1) Can't get the bulb out. Is there any sort of locking tabs, or does it just pull right out? I removed the ring, the housing, pulled back the rubber piece, just can't seem to pull the bulb out.
2) Retaining wire. The picture in the service manual does not match the retaining wire set-up I have.Yes, it's stock. I did not look at it closely before removing it (after all, I have a manual right?) and now can't figure out how the thing goes back in.
Never thought changing a light bulb could prove a challenge.
Old May 27, 2008 | 10:57 AM
RAWHIDE07's Avatar
RAWHIDE07
Default RE: Headlamp bulb help
And I thought it was just my bike!When I changed the headlight bulb on my 07 fxd(h4) I had a hard time getting the old bulb out,it's like it was glued into the connector which should simply just unplug from the bulb.I ended up destroying the old bulb to get it out.I soaked it with wd 40 and pried at the base till it finally came off.I then installed my new piaa with no problem.A few weeks later I installed a new headlight visor and easily removed the plug to clean inside the shell.Is it possible they actually glue the connectors on to discourage non dealer replacement?Or are they afraid the connector may vibrate off at night and cause an accident?
Old May 27, 2008 | 11:04 AM
USMC7236's Avatar
USMC7236
Thanks. Glad it's not just me. I'm heading over to the Indy to let him take a crack at it.
SciFiGuy's Avatar
SciFiGuy
I just replaced my stock headlight with a Sylvania Ultra yesterday. Had no real problem removing it. There is a small retaining clip you first have to remove. You will see that there is a small phillips head screw where the clip is sucured. Loosen that screw then push down on the other end of the clip, you will see that it needs to be pushed down the away from another retaining clip.
Once that done the bulb should come right out.
Now putting the clip back in thats where I had a problem. Put the new bulb in (theres only one way it will go in btw) but could not get the clip back on correctly. After about an hour of fiddgitting with it I was able to get the top of the clip on the lip where the screw is to tighten it down but still could not get it exacely the way it was when I took it off. Seems to be holding up alright so far. I've not ridden at night yet since the change so I'm not sure about any issues but I'm probably going to take it apart later this weekend and give it another try. Bugs the bejezzers out of me not having it exactly right on a brand new bike.
Anyway's hope this helps you out and if anybody else out there thats made a bulb change and has run into a simillar problem I sure would like to hear how you went about fixing the problem.
Old May 27, 2008 | 11:23 AM
RAWHIDE07's Avatar
RAWHIDE07
Thats just a spring clip,you shouldn't have to loosen any screws to remove the bulb,just unhook it from the retainers and hinge it up.ALL h-4 bulbs are mounted this way,I still don't understand why my connector was so hard to remove,i've replaced lots of bulbs in the past 40 years and have never had a problem.
Old May 27, 2008 | 01:04 PM
USMC7236's Avatar
USMC7236
OK, got thefreakin' thing changed out. Really did have to tear that bulb apart. Indy confirmed this is normal. Thanks for the advice.
Old May 27, 2008 | 01:15 PM
talon33's Avatar
talon33
3rd Gear
i have a '08 fxdb/i,changed bulb at 7500 miles no problem with plug.just for info i put in harley performance bulb,it didn't last 5000 miles.
Old May 27, 2008 | 01:50 PM
SciFiGuy's Avatar
SciFiGuy
Old Jun 30, 2013 | 11:40 AM
ktrick01's Avatar
ktrick01
I never thought I'd have so much trouble and frustration replacing a bulb. I had to rip the connector from the old bulb with pliers! Once I got it off, all went well. Only took about an hour or so.
HAP76
Sep 11, 2014 09:18 AM
Borderman
Dyna Glide Pictures
Sep 10, 2014 12:10 PM
Stanger
Aug 1, 2011 01:06 PM
hemel
Sep 9, 2008 04:41 PM
sportynjny
Mar 25, 2008 08:27 PM
