Dyno Charts This forum is for posting of your Dyno Charts. You will use a prefix to designate your Cubic Inches. When posting please include all model year, Cubic Inch and modifications in the thread title and in the body when posting your Dyno Charts.
103-113": S&s 110
Old Apr 23, 2018 | 02:33 PM
13glidestreet's Avatar
13glidestreet
Default S&s 110
Here is the final break down of the parts list
S&S 110 kit
S&S push rods
S&S 585 cams
5.4 injectors CNC ported stock 103 heads done by S&S
AIM Clutch
V&H X Pipe with 4" Rineharts with the high flow baffles
114HP 121TQ
Old Apr 25, 2018 | 10:11 PM
cvaria's Avatar
cvaria
i have that same oddball dip between 2.0 and 2.75 on my s&s 110
Old Apr 29, 2018 | 11:53 PM
rhuff's Avatar
rhuff
Something doesn't seem right. Any explanation for the massive dip? That clutch SHOULD hold that power, no? Exhaust?
Old Apr 30, 2018 | 02:23 PM
FLTRI17's Avatar
FLTRI17
This is very normal when you opt for the high flow baffles.
If you want more low end performance the std baffle will help.
That said, if you are mainly concerned with above 4K rpm power the baffle you have is ok.
Bob
Old Apr 30, 2018 | 06:49 PM
cvaria's Avatar
cvaria
see it a lot on dynos with 585s... even the T111 rocks like that.
http://starracing.com/T111SSEngine_000.php
Old May 1, 2018 | 06:08 AM
98hotrodfatboy's Avatar
98hotrodfatboy
S&S 110 kit
S&S push rods
S&S 585 cams
AIM Clutch
V&H X Pipe with 4" Rineharts with the HIGH FLOW BAFFLES..........
114HP 121TQ
Yup, that'll do it.....
Old May 1, 2018 | 05:50 PM
FLTRI17's Avatar
FLTRI17
IME by replacing the high flow baffles with the standard baffles you will feel an improvement in overall performance without giving up any usable power... anywhere.
Watch and feel that dip shallow up.
Bob
Old May 1, 2018 | 07:19 PM
hrdtail78's Avatar
hrdtail78
Cam isn't helping. What is the compression? 10.25-10.5?
izhd
May 15, 2018 11:05 PM
13glidestreet
Apr 21, 2018 11:00 PM
FBFletch
Exhaust System Topics
Mar 30, 2012 06:04 AM
yobtaf09
Mar 9, 2012 01:26 AM
jrfernandez7
Jun 27, 2009 04:56 PM
