Electrical problem: 2004 E Glide Classic
Old Nov 6, 2014 | 04:43 PM
NAPBIRT's Avatar
NAPBIRT
Stage II
Default Electrical problem: 2004 E Glide Classic
Electrical problem: 2004 E Glide Classic, 55,000 miles. Battery seems good. Yesterday, after riding home for lunch I went to start it, turned the ignition switch on, nothing. Rolled it in the garage and took the truck to work. Last night I turned the switch on and I could hear the sound it makes as things power up, little red key light lit up, speedo needle wiggled a bit and headlight slowly came on put only about half power. Tried the starter, nothing. Turned switch to Acc. and dash lights came on. Tried it all again this morning with the same results. Bad switch possibly? Hard to change? Battery? Cables? I've had the bike 3 months and it's my first. Thanks for your wisdom!
Old Nov 6, 2014 | 07:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Before you spend one penny...
Remove the battery.
Charge fully with a 2 amp charger.
Have battery load tested, an auto parts store will do this for free.
Until you know the actual condition of the battery, you can`t troubleshoot.
Old Nov 7, 2014 | 05:16 AM
grbrown's Avatar
grbrown
Sounds as if the battery is low, which could be as simple as a dying battery through old age, or faulty charging circuit. However follow Dan's suggestion and let us know what you find.
Conga
Jan 16, 2017 01:09 AM
skinman13
Sep 6, 2016 10:43 AM
Timax55
Aug 26, 2014 01:46 AM
fastalkintn
Aug 24, 2013 06:42 AM
56harley
Sep 9, 2006 01:20 AM
