Installed 10 inch mini apes on 2013 softail slim. I had to replace one 4 pin molex connector(female) and one of the pins because the pin came off of the orange/white wire from the switch housing. I also added the HD wiring harness extentions. Once I got everything put back together the bike would not start. 5 minutes later I pushed the bike back in the garage and it cranked right up. The main problem is that the engine light stays on and the alarm system light came on as well( Even though I don't have an alarm)
Where should I start with trying to get the engine light to turn off. I can't understand why it would be on. Could there be a computer issue? I did disconnect the battery when I did the install. (Any suggestions?)
Drove the bike around the corner for a test ride and here are my findings. All of the electrical(horn, high beam, turn signals, etc...) appears to be in working order. The engine light and alarm light comes on and goes off every 2-3 minutes. I did discover why the bike wouldn't start last night. It will only start in neutral. Before the bar install it would start in neutral and in gear. Will try in pull the codes this evening.
