Security Light
Old Jun 4, 2016 | 09:13 AM
Jeff42899's Avatar
Jeff42899
Default Security Light
Hello all. I'm having an issue with the security light on the speedo intermittently flashing on a 2011 Heritage Classic. The bike does not have a security system. What happens is during braking (only occurs when using front brake), the security light will flash twice then stay solid. To get it to shut off, all I need to do is squeeze and release the front brake, and it won't return until I brake again. The brake light is not on when the security light is on and the only thing I can think of is that the bcm thinks the brake light should be on and it's not, so it thinks the bulb is bad. When I activate the front brake, the brake light works as it should. Is there a brake light activation switch in there that may need adjusted or replaced? The bike is new to me and the light does not create any running problems. All lights are factory as far as I know, but controls have some chrome covers on them that I don't think are stock, so I don't know what else in the switches may have been modified. Ideas?
Jeff
Old Jun 5, 2016 | 08:06 PM
Vernal's Avatar
Vernal
I'm not familiar with Softails but on late model touring bikes with BCM's the security light comes on when there is a current codes are present in the BCM.
Check for codes.
Old Jun 6, 2016 | 06:06 PM
j_bee's Avatar
j_bee
Have you checked the bulb?
Canbus model bikes have a system where if the brake light element in the bulb is blown, it will send extra current to the taillight element to increase brightness to act as a brake display.
It would also show your security key icon to warn you of an issue.
With luck it's as simply as that.
Good luck.
Old Jun 6, 2016 | 06:16 PM
Jeff42899's Avatar
Jeff42899
Double tap
Old Jun 6, 2016 | 06:17 PM
Jeff42899's Avatar
Jeff42899
Great info guys. Thank you. I'll check the bulb first.
Old Jun 7, 2016 | 07:48 PM
Jeff42899's Avatar
Jeff42899
Well, I removed the tail light and it's an aftermarket light assembly. Time to research brightasslights to see if that assembly is the culprit.
user 8382390
May 12, 2017 03:05 PM
Tulsa Rambler
Milwaukee Eight (M8)
Jan 10, 2017 12:40 PM
jackyl
Jul 30, 2016 04:34 PM
BMyers
Apr 15, 2016 09:50 PM
KyleGT
Jul 27, 2015 10:28 PM
