Battery Light ON when Braking
Old Oct 29, 2017 | 04:38 PM
bustert's Avatar
bustert
can you post the p/n of the gauge or wiring diagram? also how you hooked it up.
yes, you can have vac readings correct even with a short to ground. remember, you are testing open so there is no load on the stator and if the short is minor, voltage might not drop enough. you could have a short between winding layers which effectively drops out put. since ac current is down, so will be dc from the regulator.
the battery light is a balance between in and out. as long as dc is high enough, the light can not ground through the system, a ground does not necessarily mean positive to negative, it can happen between two positive voltages ( or negative ) , one just being of lesser value. as the dc drops, then the light can turn on since power can flow through the light.
5wheels
Aug 6, 2018 06:33 AM
Falcon195
Jul 28, 2013 05:07 AM
kpb46
Dec 9, 2012 09:49 PM
Junior_co
Sep 27, 2012 09:26 AM
tekeum
Sep 23, 2009 04:42 AM
