The Can can?
Old Jun 1, 2018 | 11:17 AM
Muvin4ward's Avatar
Muvin4ward
Stage II
Default The Can can?
I have a 2015 nightrod. I am having electrical issues with the bike where it fails to charge since it was new. The dealership has "repaired it" 3xs now. 2xs at another dealership and once at still another. I wanted to swap and trace everything out. I would like to use the 2018 CAN-BUS, but I don't know if there could be other issues. I would be changing the front end with lights and ALL integral pieces. Because i'm changing so much of the wiring, it should be less of a compatibility issue i'm hoping. What are my chances of finding someone capable?
Old Jun 2, 2018 | 10:42 AM
Vernal's Avatar
Vernal
No Can do.
Welcome to the forum.
Nothing is impossible if you want to spend the money.....
Open the link below and look at the Electrical diagrams .Compare V Rod and Softails, Notice that the Softail has a Can Bus that gives inputs to the ECM as well as the BCM,. Looks like you would have to replace the hand controls,ECM .... add a BCM ...... and the list goes on......
And it won't help your charging problem.
https://serviceinfo.harley-davidson.com/sip/
Old Jun 5, 2018 | 01:31 AM
Muvin4ward's Avatar
Muvin4ward
Stage II
Thank you very much. Clearly a good word is money in da bank. Well thought out projects are the most rewarding and the most efficient when it comes to cost. God bless you and your knowledge. I will contact H.D. about the charging system as the dealer is trying to ignore their obligations under all warranties.
oakmossy
2014-2024 Touring Models
51
Jul 9, 2017 04:46 AM
Greg1028
Nov 4, 2016 03:15 PM
thirdjoe
14
Dec 16, 2014 02:13 AM
codpilot
11
Oct 29, 2014 07:18 PM
ohjay
Mar 12, 2014 07:34 AM
