Led Headlight Issue
Old Jun 21, 2018 | 05:08 AM
LH1965's Avatar
LH1965
Default Led Headlight Issue
Bike - 2018 883N
Swapped out my OEM headlight for a Eagle Lights Gen III headlight, now the red security (trouble code) light stays on. Bike does not have security system or key fob. Cranks and runs fine, just the red light on all the time. Eagle says plug and play, just put in and ride. Thought I would ask here for real world advice. Anyone else having this issue?
Thanks in advance
Old Jun 21, 2018 | 02:32 PM
Zanthamos's Avatar
Zanthamos
Red light indicates trouble code stored due to CANBUS system, you need to get the CANBUS module.
Old Jun 21, 2018 | 03:13 PM
LH1965's Avatar
LH1965
Ok, Eagle just said plug and play so I didn't look any further. Will look into the CANBUS issue....thanks for advice.
Old Jun 21, 2018 | 04:09 PM
bustert's Avatar
bustert
yep mr. zan is right!
some can systems look at light load to determine if they are working or burned out. for that reason, they make can compliant replacement bulbs, you might have to mod the wiring to trick it.
Old Jun 22, 2018 | 08:32 AM
LH1965's Avatar
LH1965
I will follow up with the resolution.
Old Jun 27, 2018 | 04:28 AM
Lin Edc's Avatar
Lin Edc
1st Gear
Yes, I also encountered this problem, but I should not touch the small cheap in novsight
RiverCityRocker
Aug 13, 2018 01:46 PM
Dosahl
Electrical/Lighting/Alarm
Sep 21, 2017 09:58 AM
meat_ball
Sep 23, 2016 10:44 AM
ghicks80
May 27, 2016 05:22 PM
Aversocki
2014-2024 Touring Models
Oct 7, 2014 07:36 PM
