Need Help: Security light flashing while driving
Old Oct 5, 2014 | 03:54 PM
Aversocki's Avatar
Aversocki
Default Need Help: Security light flashing while driving
So on Saturday I swapped out my headlight for the reflector headlight and since then everytime I start up the bike and start riding the security light comes on and stay on for few seconds then turns off and back on basically flashing real slow no matter what gear I'm in or whether I'm driving or not.
Anyone know what is causing this and how to get it to stop?
Thanks!
Old Oct 5, 2014 | 05:46 PM
06SGWA's Avatar
06SGWA
I think that light means that a code has been thrown. I don't know what kind of light you installed but could it possibly require a load equalizer?
Old Oct 5, 2014 | 05:55 PM
jpalm's Avatar
jpalm
I don't know if this will work for sure or not, but give it a shot. The low draw of an LED light might be tricking the bike into reading the headlight as being blown. Hold down the power button on the radio when you turn on the bike and that will bring up all of your codes. Once in there, you should see a code displayed relating to a headlight issue. I know there's a way to reset the code, but I haven't personally done it. Give that a shot. Can't hurt, might help.
Old Oct 5, 2014 | 09:28 PM
Aversocki's Avatar
Aversocki
I installed the LED reflector made by harley....awesome thanks I'll try that!
Old Oct 6, 2014 | 07:14 AM
Bohacker's Avatar
Bohacker
The load equalizer is not required for the 2014s. I installed the daymaker reflector with no load equalizer and no issues. Must be something else. Hopefully you can read any codes that were thrown. Should at least point you in the right direction.
Old Oct 6, 2014 | 07:46 AM
TimLScheffer's Avatar
TimLScheffer
Try Pulling the Master Fuse to reset every thing...
Old Oct 7, 2014 | 11:50 AM
Kevinch's Avatar
Kevinch
I know the instruction sheets for most of the accessories & procedures instruct you to pull the main fuse before doing anything else. I wouldn't be surprised if they told you that before checking tire pressure.
Old Oct 7, 2014 | 07:36 PM
Bagger Bum's Avatar
Bagger Bum
Make sure you didn't crush any wires. Also check your taillights. I changed out some turn signals on the front and that's what happened,
RiverCityRocker
Aug 13, 2018 01:46 PM
LH1965
Electrical/Lighting/Alarm
Jun 27, 2018 04:28 AM
Josh Bloomfield
Feb 20, 2017 03:26 PM
ghicks80
May 27, 2016 05:22 PM
jmn1960
May 10, 2014 01:56 PM
