Security light stays on. Error code b2206
Old Jan 21, 2019 | 12:38 PM
David Hardie's Avatar
David Hardie
Default Security light stays on. Error code b2206
Greetings all. I'm new to this site. I've got an issue with my security light staying on my 2018 Road Glide Special. Could really use some direction. I recently put on a new pair of 12" monkey bars and after completing, my check engine light was on, so I ran diagnostic and cleared codes, but red security light stays light. Run diagnostic again and ECM is clear, but BCM says b2206 "run/stop switch input open/shorted high" and it wont clear. Everything appears to be working fine........any input would be greatly appreciated
Old Jan 22, 2019 | 10:24 AM
skinman13's Avatar
skinman13
Start by going back over your work starting with the right controls wiring...sounds like the code is indicating that you may have pinched or broken a wire.
Old Jan 22, 2019 | 12:46 PM
TexasMotorcycleRider's Avatar
I had the exact same thing recently with a pair of 12" Twin Peaks bars. Turned out one of the pins on the extension wires puled out. I had to pull the extension cables and plug the pin back in, it wasn't broken...just never inserted all the way so it pulled out when I was installing and I didn't notice it.
Either way, it's likely related to wiring on the throttle side. If you search "b2206" there is another thread with a few suggestions.
Old Jan 22, 2019 | 03:39 PM
Vernal's Avatar
Vernal
Dave I posted in your other thread too, from a 2015 manual.
David Hardie
Jan 21, 2019 04:21 PM
stan60
Jul 29, 2017 02:27 AM
Ashnic
Milwaukee Eight (M8)
Mar 21, 2017 08:53 PM
Naz_Man
Mar 28, 2006 05:46 PM
fiddledicksr
Feb 18, 2006 12:32 PM
