Engine light?
Old Mar 20, 2017 | 07:30 PM
Ashnic's Avatar
Ashnic
Default Engine light?
Hey guys just got done putting my bars back on after having some light machine work done to them so the throttle grip fit better. Plug everything in and torque everything down, cranked up bike and have the engine light on..how can I get a code or reset? I know I have read it before somewhere..
Old Mar 20, 2017 | 08:08 PM
timbo141's Avatar
timbo141
To access the diagnostic menus, hold the power button of the infotainment system in while turning the ignition switch to the accessory position until the warning screen appears. Then, release the button and click accept.
The service menu will be displayed. To view diagnostic trouble codes, highlight and select DTCs on the display. A listing of all current and historic codes logged will be displayed. Selecting the "i" button will change the display so that it lists a description of the code rather than the code number.
Old Mar 20, 2017 | 08:45 PM
CR3999's Avatar
CR3999
Probably something to do with the speedo. Mine came on after changing the bars. I cleared it and the light never came on again.
Old Mar 21, 2017 | 05:51 AM
Ashnic's Avatar
Ashnic
How did you clear the code?
Old Mar 21, 2017 | 08:04 AM
lp's Avatar
lp
https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Mar 21, 2017 | 08:12 AM
Drodrigueznyc's Avatar
Drodrigueznyc
it's always good to capture this info on your smarphone. I have it copied into a note on my iphone for future reference. I also keep instructions on how to put to override the security should I lose the fob as well as how to put the bike in transport mode. all good things to have when you find yourself in trouble.
Old Mar 21, 2017 | 08:56 AM
Ashnic's Avatar
Ashnic
Good advice!
Old Mar 21, 2017 | 04:56 PM
Ashnic's Avatar
Ashnic
Thanks for all the help guys..had a code in everything..cleared them up and everything is good to go..even took a little 20 mile cruise...
Old Mar 21, 2017 | 08:53 PM
CVO SG's Avatar
CVO SG
I had same thing, a dozen codes after new bars installed. Cleared them and all is good. Pretty sure mine was from turning the ign on double checking the wiring in the bars w/o all of the plugs plugged in.
Floppy Junk
Oct 2, 2012 07:48 AM
SE120RG
Jul 20, 2009 08:00 AM
johnnyshrooms
Jun 11, 2008 10:23 PM
patsac
Feb 20, 2008 08:32 PM
KeithB
Exhaust System Topics
17
Nov 2, 2006 09:48 PM
