Raptor Shift Light
Old Dec 13, 2019 | 04:26 PM
mmclaughlin316@yahoo.com's Avatar
Default Raptor Shift Light
2016 FLHP. My first big Harley. Can't hear above 3500 RPM. Bought a Raptor shift light (SL). Tried Engine Control Module (ECM) Pin 3 White/Violet "blunt cut" tach output as the SL trigger. Did not work. Next step per SL instructions, ECM Pin 2 GN/BE...front ignition coil trigger..did not work (my fault...read on). Per Raptor, tried ECM Pin 5 Green/Yellow front fuel injector trigger..worked, but shift light lit up randomly at part throttle. Went back and reconnected to Pin 5 ignition coil snd has worked perfect since then. Very easy for me to think the problem was with the equipment when it was really with my workanship.
babineaux66@msn.com
Oct 28, 2009 09:43 PM
Fatbob_Bob
Aug 7, 2009 09:48 PM
ray1970
Jun 28, 2008 05:34 AM
ggibson
Jan 30, 2008 09:06 PM
MaineHD
Mar 5, 2007 03:14 PM
