Lets talk headlights
Old Feb 11, 2020 | 09:00 AM
Goose_NC's Avatar
Goose_NC
Before you go spending money on fancy halogen bulbs, do some basic tests. Many older motorcycle simply no longer get 12vdc to the halogen bulbs. I have run a wire directly from the battery to two relays. Using the stock wiring to trigger the relay to power the halogen headlight, I was able to increase the light output. I have done this on several older motorcycles.
Old Feb 11, 2020 | 09:18 AM
Guppy916's Avatar
Guppy916
Goose that's a good call I bet not many of us check that, I'm off to check the sportster's volts
Old Feb 12, 2020 | 01:41 PM
Guppy916's Avatar
Guppy916
Right I have battery voltage at the light terminals so no drop, off this is on a 1999 883 sportster
Old Feb 12, 2020 | 01:50 PM
cprhed's Avatar
cprhed
Hey Man, the biggest answer in a standard halogen bulb is gonna be a Silverstar Ultra. But for the cost of that one you should call DK Customs and ask them about their direct LED replacements. In my 08 ultra I did that. Not the whole headlight swap, just swapped to their direct plug in LED bulb replacement. I have been very happy. It is brighter but I have been told it is not blinding and the wavelength (color) of the light catches reflector signs way farther than a stock light.
flyingchipmunk
May 4, 2017 11:00 AM
harleyfiremedic
Mar 22, 2016 09:21 AM
asianiron
Jan 31, 2016 12:51 PM
rodney123456
Aug 3, 2014 07:32 PM
wild_one
EVO
26
Mar 28, 2013 02:00 PM
