Red key light on, no start
Old Feb 22, 2020 | 12:15 AM
Jenna6112's Avatar
Jenna6112
Stage II
Default Red key light on, no start
05 HD ROAD GLIDE......Purchased bike 2 weeks ago. Red key light has been on since day 1 but wasn't affecting anything. Go out today to go for a ride, went to start bike as usual and it won't even crank....DEAD. Key light blinks and blinkers flash then key light is steady on. I replaced battery in key fob.....still nothing....DEAD. Now what??? My other bike is down as well. 2 bikes and can't ride neither of them. HELP
Old Feb 22, 2020 | 06:59 AM
smitty901's Avatar
smitty901
If you are getting the red light and flashers coming on it is likely a security issue. Not sure how you do it on the 05 but you can by pass the fob with entering a code . I hope someone gave it to you. You could try this Pull the maim fuse. take battery out of fob. Put main fuse back in put New battery in fob. Try again. The red light should flash from time to to when shut off but not stay on all of the time. If it is one all of the time there is a code some where. Of course make sure your battery is fully charged .
Old Feb 22, 2020 | 07:00 AM
Kawickrice's Avatar
Kawickrice
Could be a weak battery in the bike also.
Old Feb 22, 2020 | 07:20 AM
CoolBreeze3646's Avatar
CoolBreeze3646
As this is your first post, welcome to the forum. Do a search as this topic has been covered a few times in the last year. Good Luck!
Old Feb 22, 2020 | 11:44 AM
nevil's Avatar
nevil
The last time that happened to me it was the battery fob. When a new one didn't help, I reinstalled the battery the correct way. Can't hurt to check it.
Old Feb 22, 2020 | 11:49 AM
barneyboy's Avatar
barneyboy
https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Feb 26, 2020 | 08:04 PM
Ed Ramberger's Avatar
Ed Ramberger
Little known trick that comes into play after dead batteries sometimes. Turn ignition on to power up bike and turn it off - don't need to try and start it. If you are certain the NEW FULLY CHARGED fob battery is installled correctly, hold the button down on the fob near the left handlebar switches for up to a minute or more. You are going to hold it until it arms (2 flashes of signals). Then disarm and arm it a few times to verify function. It should then start.
It is not uncommon for the fobs to need a little help talking to the TSSM after a battery situation like yours.
Old Feb 28, 2020 | 05:37 AM
kel03's Avatar
kel03
Well, 6 days and the OP hasn't been back, her computer battery must be out also..........
Old Feb 28, 2020 | 06:23 AM
Ed Ramberger
Another one post wonder.
Old Feb 28, 2020 | 06:39 AM
Iceman24's Avatar
Iceman24
Yep, gets old...join, post question & leave. I say mods should delete these accounts, if there's ) activity f/ one week.
