1992 fxrs turn signal problems
Old Apr 29, 2020 | 06:20 PM
92fxrs89's Avatar
92fxrs89
Stage I
Default 1992 fxrs turn signal problems
Hello. Have a 92 fxrs. I had changed out the headlight and have a mess of wires from the old bucket. Headlight is wired turn signals. SO THE PROBLEM IM HAVING IS, when I hit left turn signal it stays on when I hit the right side I get no light.
Old Apr 29, 2020 | 06:46 PM
BuzzCap7's Avatar
BuzzCap7
What? 92......you come in here and ask a question right off. Don't we get a kiss or sum'ting 1st mate? Huh.
How do u like them apples?
It is optional my friend but you can click
HERE and that will take you to our Welcome Area Only where you can introduce yourself as well as several of us would like to welcome you here.
That is also where you see the HDF rule. On the upper portion of the Welcome Area Only where the “Sticky’s” are. Like where to post what.
See below, this little chart thingy here is just for you mate.
This chart will help you post in the right forum.
'hope to see you in the welcome forum.
BuzzCap7
Old Apr 29, 2020 | 06:47 PM
Silentgreyfellow's Avatar
Silentgreyfellow
I would suggest getting a factory service manual with the electrical diagrams if you don't have one already. Then take a look to make sure all the wires are connected correctly and are in decent shape.
Old Apr 30, 2020 | 12:18 AM
Zanthamos's Avatar
Zanthamos
BuzzCap7, why are you acting so phallic? This guy is posting on the correct forum, your post was completely uncalled for.
That beng said, yes a wire diagram is definitely in order. How much of the wires in the headlamp bucket is original harness and how much is messed with by the previous owner?
Old Apr 30, 2020 | 01:34 PM
BuzzCap7's Avatar
BuzzCap7
Hi there Zan. Is that how you read the post I made above?
I used that post many times. No one (that I know of until now) read it as unpleasant.
It was supposed to be joking and light-hearted. Huh. I'll have to look at the post again and maybe re-do future posts so it comes off more in a happy joking manner.
Oh, I almost forgot, if I am not mistaken, this post is in the right spot as you mentioned above Zan, bcs I moved it here from the wrong spot.
Thanks for your input Zan. Have a GREAT day!!
BC7
Last edited by BuzzCap7; Apr 30, 2020 at 01:37 PM. Reason: Added the, "Oh, ..." line.
Old Apr 30, 2020 | 02:51 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
BC7
It would be helpful to indicate that the post was moved, because it certainly isn`t obvious...
I have never understood the idea of the welcome area I guess...
That type of response is uncalled for...
Old Apr 30, 2020 | 03:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
92fxrs89: you posted a tech question in the welcome area of the forum, which is supposed to be for introductions only.
Your post is now moved to the correct area...
Please explain what you mean by this
Let`s chase down one problem at a time:
Left signal stays on....Are both the front and rear turn signals illuminating (but not flashing)?
Are the front running lights in the turn signals both working?
Old Apr 30, 2020 | 03:13 PM
BuzzCap7's Avatar
BuzzCap7
Dan, THANK YOU for your input. I appreciate that. I'll modify the "...response..." since you and Zan have commented on it.
I would like for it to be clearer and will take care of it. Thanks again pal!
BC7
Old Apr 30, 2020 | 03:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Thanks Buzz!
Old Apr 30, 2020 | 03:45 PM
Zanthamos's Avatar
Zanthamos
Im hoping that this exchange didn't turn the OP off of asking for help on this site.i appreciate the clarification and no hard feelings.
