What does the i button do?
Old Jul 29, 2020 | 10:32 AM
Wide06's Avatar
Wide06
Default What does the i button do?
I haven't found yet what the "i" button (the other half of the right turn signal button) on the right hand control does.
2018 FLHP Road King Police (but this button isn't specific to the police models). I haven't seen it in any of the books, manuals, or wiring diagrams. I also haven't found a change in any of the the harness wires with a voltmeter when this button is pressed.
Old Jul 29, 2020 | 11:10 AM
m1369x's Avatar
m1369x
Police Bike, Must be Self Destruct button
Or a removed cop option
Sorry I'm no help
Old Jul 29, 2020 | 12:09 PM
barneyboy's Avatar
barneyboy
Old Jul 29, 2020 | 12:54 PM
todd-67's Avatar
todd-67
I don't think it does anything on a road king. It only works with a boom system with a screen.
Old Aug 9, 2020 | 04:23 PM
Zanthamos's Avatar
Zanthamos
It is for the glides series bikes, they put the wrong switch module when they decommissioned your bike. They were supposed to replace the police switches with the RK switches.
Old Aug 10, 2020 | 09:45 AM
Lunchboxx's Avatar
Lunchboxx
on my bike, 2015 Ultra, I brings up a screen on display that that shows oil pressure, Status of eitims and Ai temp I think
Old Aug 10, 2020 | 10:39 AM
470004's Avatar
470004
A photo of this switch would help.
Old Aug 10, 2020 | 11:39 AM
barneyboy's Avatar
barneyboy
Old Aug 28, 2020 | 10:53 AM
Wide06's Avatar
Wide06
This dealer doesn't remove the police switches. I found, and see above, that the i switch is for other bikes. I wonder if it was used/programmed for a police function. May never know, but I'm also trying to find out if the BCM can be manually programmed for different functions of extra switches. This would be a good garage door opener button.
Old Aug 28, 2020 | 07:35 PM
Zanthamos's Avatar
Zanthamos
Dealer does remove switches, I did so at the dealership last year, we are required to decommission police models prior to civilian sale. Part of the decommission is swapping the switch modules to civilian variants and replacing the red/blue passing lamps to clear, removing the passing lamps flasher and installing a passing lamp switch. The hardest part on a 2019 is that the HD tech support at the factory didn't document where to get power for the lamp switch.you do not have the red stick style switches below the turn signal.
andyshd
Electrical/Lighting/Alarm
Nov 1, 2014 03:31 PM
redbeard14
Apr 10, 2014 06:05 PM
bikercouple
Apr 2, 2014 08:54 AM
eastcoastink
Jun 26, 2012 08:45 PM
mja52403
Aug 25, 2011 09:52 AM
