Lithium battery can cause damage.
Old Jan 26, 2021 | 03:50 AM
Bobby knicks's Avatar
Bobby knicks
6th Gear
Default Lithium battery can cause damage.
Thinking of moving battery under seat on my 91 flhs but rumour has is it a lithium battery can mess up the regulator/rectifier...anybody had dealings with this?
cheers
Bob.
Old Jan 26, 2021 | 04:09 AM
JayStronghawk's Avatar
JayStronghawk
I used one on my 1st Run Indian Scout and worked far better than the low cranking amps OEM and didn't have enough space to fit any Lead Acid Battery and never had a problem .. Think this link will tell you a lot more than I could spend typing a long time .. Gives good details of what works and what does not ..
https://www.fullspectrumpower.com/bl...ery-in-my-bike
Old Jan 26, 2021 | 12:57 PM
Bobby knicks
6th Gear
Default Good article
Thanks for that...very informative.
Bob.
Old Jan 28, 2021 | 09:04 PM
Zanthamos's Avatar
Zanthamos
No issues that I've seen, even HD is selling LiPo batteries.
Old Jan 28, 2021 | 10:19 PM
NODYNA's Avatar
NODYNA
Had the H-D lithium for a year now moved from old to new bike no issues. Did it for the weight reduction when the dealer had a 20% off sale.
Old Jan 28, 2021 | 10:49 PM
TwiZted Biker's Avatar
TwiZted Biker
cheers
Bob.
You'd need to update your charging system on a 91 to run a lith. battery, they need between 13.8 and 14.4 volts constant to charge right and that year I think it barely gets to 13.4V maxed if it isn't tired.
Old Jan 29, 2021 | 05:27 AM
Campy Roadie's Avatar
Campy Roadie
Weight reduction on a Harley
It's like throwing deck chairs off the Titanic.
Old Jan 29, 2021 | 07:43 AM
Cobra1's Avatar
Cobra1
If lithium batteries are so good, I just wonder why new cars and motorcycles don’t come with them. After all, they have been available for a many years now.
Old Jan 29, 2021 | 07:54 AM
NODYNA's Avatar
NODYNA
Simple they cost more than lead acid batteries.
Old Jan 29, 2021 | 08:05 AM
luckiestiff's Avatar
luckiestiff
I've been running a lithium battery on my chopper, under my butt, for 5 going on 6 years with zero problems
