If lithium batteries are so good, I just wonder why new cars and motorcycles dont come with them. After all, they have been available for a many years now.
Cold weather can be critical no question and if not addressed may lose enough voltage it won't recover .. If I were to by another LiFePo Battery would definitely make sure I have the proper tender for it .. Another thing about cold weather is turn your lights, radio, flasher whatever and although sounds strange in cold weather raises your voltage for proper starting as load warms the battery up ..
The last part of this is a little mumbled. Are you saying to turn all your electronics on before starting the engine?
Yup, lith batteries need to " wake up" a bit to produce max output. Run one in my high compression shovel, if I just hit it she'll grunt and barely turn over. Turn the lights on for a couple minutes the hit the button it'll spin her normally.
Counter intuitive but it works.
Oh, so that tip only applies to lithium batteries?
