Super Cool Guy Here
The VR was installed on the wrong stud of the main CB as it should have been put on the silver side not the copper side, this helps protect the battery in an over current condition, the pin 30 of the start relay definitely looks like you need to depin it and repair, likely will cause starting issues, check for voltage at that wire as it is the supply wire for the solenoid power. You can bench test the solenoid by applying 12vdc to the small green wire and ground to the case of the starter, it'll either kick or it won't. If it kicked and the solenoid is removed from the starter then you can with power applied to the electromagnet side you can check the continuity between the two big conductors to verify power going from battery to the starter.
I assumed I might be wrong because of the conflicting diagrams.
The more I thought about it the more it seems that this configuration shares the postive power from battery and starter as well as the power from the charging system before heading across the circuit breaker and into the rest of the bikes wiring...while protecting the bikes circuits from an overload from over charging from regulator...It would be better to destroy the battery than melt the wiring no? In any case the postive cable that runs down from the cb to the starter and back up to the battery isn't going through the circuit breaker is it? Seems like its just going across it... maybe it still works the same I guess. Copper side has a b for battery side too doesn't it. I watched a video with a cut out and its the copper side that does the breaking...?
1994 wiring diagram is different... the opposite.
However my starter relay wiring was wired as if it was a
1994.
I guess maybe it doesn't matter if all its doing is energizing the coil.
its a 30 amp in 93 and a 50 amp in 94.
I wonder why mine has a 50 amp.
Does the 94 voltage regulator put out more amps?
I know that at some point the output voltage went up but that wouldnt increase that many amps.
Otherwise do you know why they went with a higher amp breaker?
I noticed they have more cbs up front totalling 91 amps
The 93 only totals 70.
I NEED more time with this manual... I'm mixed up about alot. Lol
The other wire goes to the same place as my postive cable from battery. I believe it is specifically the starter motor power supply from battery direct. I'm finding more wiring diagrams saying that my wiring is correct....
this one below doest show poles at all
The second diagram shows your way...I think the difference is 1993 vs 1994.. the main circuit breaker is wired very differently and different things are paired together. My 1993 is wired as if it was a 1994.
The important thing to figure out is why someone did that... i shouldn't religiously follow 1993 diagram if 1994 like changes or aftermarket demands like stereo have been made to the wiring. I need to understand better.
Look here
The layout of the clymer diagrams are not great, a lot of them are incorrect.
Here is the real deal:
Harley Davidson Service Information Portal
Most vehicles have no breaker between the alternator/voltage regulator and the battery. Harley connected the VR at the copper stud for many years.
