Battery question.
Old Apr 25, 2021 | 04:18 PM
REW13's Avatar
REW13
Default Battery question.
Might be dating my age here..
But is it possible for a battery to die while riding the bike and the f'ing thing cut off? I remember my old enduro would run with a dead battery just had to push start it..
Old Apr 25, 2021 | 04:40 PM
bad tappets's Avatar
bad tappets
It’s possible your battery just up and died, but other causes are far more likely. Your old enduro had a magneto, so it could run without a battery.
Old Apr 25, 2021 | 08:02 PM
REW13's Avatar
REW13
Ahhh... Thanks... That was me thinking out loud while broke down on the side of the road... Was tickled pink..
Old Apr 25, 2021 | 08:08 PM
TriGeezer's Avatar
TriGeezer
Instant death of a battery likely was a internal short, which would draw down the voltage.
Old Apr 28, 2021 | 10:34 AM
REW13's Avatar
REW13
And it was just my luck to be 70 miles from the house when it chose to die..
Got 2 years from a 6 month warranty battery tho
Old Apr 28, 2021 | 01:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The charging system could have failed, the bike will run until there isn`t enough in the battery to support the electrical system.
Old Apr 29, 2021 | 10:00 PM
0003's Avatar
0003
Brother in law cracked his negative ground tobth3 bike not battery. Lost all power. If yours showed signs of life then probably not the case...but if its absolute zero with no signs of life then maybe.
Old Apr 30, 2021 | 06:35 AM
bustert's Avatar
bustert
+1 on the magneto, but:
a pmg system will run without a battery also. a lot has to do with the type of VR. if you could push fast enough, the pmg will output enough volts/amps to run the system. however, with the big brothers looking out for ya, it would be a tough sell due to the electrical load mandated, aka, lighting.
if you look at the hd schematic, you will see the VR is tied in after the battery and when the battery is fully charged, the system runs off the VR and the battery making up the short fall.
i used to run my tricked out honda 305 scrambler without a battery on the track and used a 12v dry cell for the street. push off vs kick, had electric foot but required a better battery than a lantern type. the VR was a selenium type, simple but worked.
Old Apr 30, 2021 | 07:08 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Load test battery, test charging system.
Old Nov 5, 2021 | 11:52 PM
mattyhaig's Avatar
mattyhaig
6th Gear
Sorry wrong post.
AaBorokokok
Electrical/Lighting/Alarm
Jul 24, 2018 02:59 AM
Ragnar Danneskjöld
May 30, 2012 05:21 PM
raidernut
Jan 31, 2010 09:27 PM
Fuzzman
Jan 12, 2010 10:22 PM
emtkyle
Sep 28, 2008 10:34 AM
