Data Link 2000 Softail
Old Aug 28, 2021 | 07:11 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Default Data Link 2000 Softail
Hi, I am looking for some general info here.On a 2000 softail, I need help identifying the signals. The data link connector has 4 pins. #1 is light grn/red stripe connected to pin 11 of the gray connector of the ign module. # 2 is blk and connected to ground. #3 is labeled V/R and goes to pin 12 of the gray ign module connector. #4 is white with a black stripe and goes to pin 1 of the black ign module connector. What is the signal on pins 1,3,&4 of the data link ?
Thanks
Old Aug 28, 2021 | 08:34 PM
Zanthamos's Avatar
Zanthamos
On the 2000 the data connector just links the ECU to the Scanalliser tool that most HD dealerships no longer have it wasn't until 2004 that other items were put on the data bus.
Old Aug 29, 2021 | 09:58 AM
CarlosGGodfrog
Thanks, I have a scan tool, I am just looking for the signal designation. What does V/R stand for ?
Old Aug 29, 2021 | 07:43 PM
Zanthamos's Avatar
Zanthamos
As in color code? Violet with a Red stripe.
Old Aug 30, 2021 | 11:31 AM
Vernal's Avatar
Vernal
Thanks
The W/BK is 12V from the Off/Run switch but I don't know what the LTGN/R or V/R are. Maybe Z can tell us?
Old Aug 30, 2021 | 10:19 PM
Zanthamos's Avatar
Zanthamos
BK is ground, WHT/BK is ignition power, LTG/R is the Serial data wire and the V/R is the Flash PIN wire.
Old Aug 31, 2021 | 07:38 AM
CarlosGGodfrog
Great, thank you.
Old Jun 20, 2024 | 04:31 AM
Max9's Avatar
Max9
4th Gear
Question for my Dyna 2002: Can I use the BK mass and WHT/BK ignition power for accessories power?
For example, charging my phone with a USB charger to 5 volts
Old Nov 25, 2024 | 07:15 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
That has been done by other Dyna owners.
Here;s another IMO more secure and safe option though...
Originally Posted by FXD2003Rider
Here's how to create a switched and fused 12 volt connection for your phone charger without splicing into the harness.
A ground connection for the charger can be found under the seat or at the upper tripple tree.
Old Nov 25, 2024 | 08:17 AM
CarlosGGodfrog
Slick. Where do you buy something like that ? Part # ?
