01 Electra Glide BIG POP!!
Old Sep 12, 2021 | 04:31 PM
glcashx2's Avatar
glcashx2
Stage III
Default 01 Electra Glide BIG POP!!
Charged battery, bike has been sitting for a few months and went dead. Charger indicated the battery was ready to go. I unplugged the charger turned the switch on and heard a big pop!!! What was that? Main fuse? If so where is that located? Oh it is a 01 Electra glide
Old Sep 12, 2021 | 06:29 PM
Ed Ramberger's Avatar
Ed Ramberger
Perhaps it was the weasel...
Old Sep 12, 2021 | 06:36 PM
MURPHCC1's Avatar
MURPHCC1
...maybe the cherry....????
Old Sep 12, 2021 | 11:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
As you may have guessed, there is no way we can tell you where a sound came from...
Does the bike have electrical power?
Old Sep 13, 2021 | 07:53 AM
glcashx2's Avatar
glcashx2
Stage III
When I turn the switch there is no power at all!
Old Sep 13, 2021 | 08:06 AM
MURPHCC1's Avatar
MURPHCC1
Do you know how to check electrical stuff?
Gonna have to give us more info about mods to the bike and your level of skill in diagnostics.
Old Sep 13, 2021 | 08:46 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Read the voltage across the battery posts (not the cable terminals) with the ignition off.
Read again with the ignition turned on.
What are your readings?
Old Sep 13, 2021 | 01:20 PM
NODYNA's Avatar
NODYNA
If you don't have an owners manual you can view one on the H-D.com site under owners to find the fuse location. Try the university of you tube you may find a tutorial there on the mail fuse location.
Old Sep 14, 2021 | 07:26 PM
Zanthamos's Avatar
Zanthamos
First thing I would look at is the main CB, big pop can happen CB blows, then no power at all to anything. Main CB could be in a permanent failed state as well, disconnect both terminals and check for continuity across. Battery could also have an internal short so as Dan suggested check the voltage across the terminals, this would also cause a big pop and then no power. If you are not confident in doing electrical work then I would suggest that you take it somewhere to get looked at (dealership, reputable Indi, etc. . .) as these can be a game of chance to see where the pop came from. I recently worked on an Electra Glide that had the battery leg of the maxi fuse rubbing on the ground connected to the starter. I had to replace the and reroute the wire to prevent a recurrence of the chaffing issue. This got my attention as I was jacking down the rear end to do a rear tire change and had a big pop with sparks. If the other leg had worn through this would have popped the maxi fuse.
Abaker
Jun 18, 2018 09:46 PM
papagino
Mar 29, 2017 11:42 AM
mudhen
Mar 18, 2015 09:22 PM
heng
Oct 23, 2009 03:57 PM
jpdubbs
Jul 2, 2008 11:18 PM
