Voltage drops significantly when breaks applied.
voltage regulator tested bad, as well as the batteries. Granted, the second one may have been unwarranted. Getting ready to do some testing now.
ok.. load tested battery (I happen to work at AutoZone). Tested good, 11.79 volts 0% charge.
with engine running, 14.05 V @3600 rpm.
I couldnt get any ready on my meter across the regulator pins. It would show a number then drop to zero.
positive probe on regulator pin and black on negative batt post started about .55 volts and dropping as I watched.
stator check, I believe is fine.. aprox 19.5 vac @1k rpm and 39.5 to 40.1 vac @2k rpm.
You say the voltage drops significantly, have you verified this with a voltmeter (not the dash voltmeter)?
Connect a voltmeter to the battery posts and read the voltage with the engine running, spotlights on.
Does it read the same as the voltmeter in the dash?
Does the turn signal cause the voltmeter to vary like the dash voltmeter?
If you have to charge the battery after a few days, either the battery is bad, or you have a parasitic drain.
Disconnect the negative battery cable from the battery post.
Set your meter to read milliamps.
Touch one probe to the negative battery post.
Touch the other probe to the disconnected end of the negative cable.
What is the milliamp reading?
Wiring Diagrams and Troubleshooting
its not just the volt meter on the dash. When I hit the brakes the radio will stop working for a second, the lights dim, at certain points the blinkers wont work.
Ran out of time during lunch so will do the other tests suggested when I can.
Reason:
Perhaps the wire loom is damaged in some way due to wire scrub from tire and when pressing the brake it causes a another circuit to energize.
