DVOM and Stator test question
When I got home I put the battery on the battery tender and when it was fully charged I did a load test (carbon pile tester) and a battery test. All looks good. Battery (Deka ETX30L) is only 44 months old
I'm testing the stator today. According to the factory service manual, I should read 0.1 to 0.3 ohms across the stator terminals. I'm reading 0.0 ohms with my Klein CL800 meter. I actually have a replacement stator I purchased a few months ago (Cycle Electric CE-8012). I tested the new Cycle Electric stator and I'm also reading 0.0 ohms. I've placed the meter in both auto ranging and non auto ranging modes and I get the same reading. Am I doing something incorrectly with my meter trying to read the ohms?
This is supposed to be a good meter. I'm surprised it can't measure the resistance.
I'm thinking the voltage regulator may be defective. I did notice the voltage drop on my gauge (11 volts) just before my lunch stop. And after lunch, I saw the voltage jump to 15+ volts. I've never seen the voltage go that high as I was riding in the past.
As for the meter, Klein is real decent. Does it have the ability in non-auto to be set at 1 ohm? Some of them will move the decimal point to the left, if you can get it to say 0.000 that would be the lowest and should be able to read it.
When using all 3 heated gear next time, try turning off the radio and see if the voltage gauge goes up. Perhaps just too much draw?
I also measured the DCV of the voltage regulator and it measured good. But I still think I may have an intermittent problem with the voltage regulator. I'll keep a close eye on my voltage gauge for the next couple of weeks.
Thank you!
the pmg is not an alternator of sorts largely it is not excited. the pmg is fixed and operates best if it is in designed rpm range. if you pull too many amps at a low rpm, you will see the voltage go down. the hd regulator is tied in to the battery ahead of the system so if you have issue with the battery or circuits, it will max out. if system is operating as designed, the machine runs off the regulator and the battery making up the short fall, but if the short fall is too great, the battery will discharge. figure your total system load and add 20% needed to maintain battery, if not within pmg range, you need to reduce load.
if you make a test harness, you can have the regulator tested at many auto parts stores.
i had an issue similar and it was not detectable until total fail was knocking at the door. it was a corroded out connection on the pmg wire to harness inside the primary. it would ohm correct but there was not enough strands to carry the load.
remember, the pmg output is AC and the amperage is a fraction of the DC coming out the regulator.
what type of oil do you use?? if it contains a sulfur additive used as an ep, it will react with the copper and dissolve it.
