View Poll Results: bike wont start when engine hot
engine hot wont start
50.00%
starts when cold
100.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Starting
Old Feb 9, 2025 | 12:36 AM
Ian@6078's Avatar
Ian@6078
4th Gear
Default Starting
Bike wont start if I ride it and stop,engine wont spin,,like battery flat, leave it to cool down then it spins and starts, any help please?
Old Feb 9, 2025 | 12:38 AM
Ian@6078's Avatar
Ian@6078
4th Gear
flippin mdifficult
Old Feb 9, 2025 | 05:27 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Battery cables first check. Then a good charge on a low amp maintenance charger. Then voltages checks.
Then remove battery and a CCA check of battery on a good machine designed for the small bike batteries.
PS.. Welcome to the HDFORUM.
Old Feb 9, 2025 | 08:54 AM
Rounders's Avatar
Rounders
Any mods to the engine and when did this start? When did you buy it? Interesting that even if a bad battery or loose cable, that it would still start cold.
Old Feb 9, 2025 | 09:00 AM
MURPHCC1's Avatar
MURPHCC1
What does a POLL have to do with this?
Am I missing something?
Old Feb 9, 2025 | 09:13 AM
Jackie Paper
Note that he said won't crank. Battery stuff mentioned in post three is where one starts to eliminate the basics.
If that was good, if I heard a relay click, I would check starter solenoid .
However, we don't even know if we are dealing with a Moped or a Harley with a BCM.
It's winter. Let's just play along. or
Poll is good. Both choices work. I checked.
Old Feb 9, 2025 | 09:18 AM
Rounders's Avatar
Rounders
I agree check the basics. But I just find it interesting that it would crank when cold, but not hot, on a stock motor. Which we don't know. Maybe some big high compression motor, which I have no expereince with and he is not using the compression release, because he just bought it and doesn't know they are there? Even bad electric compression release on a stock motor, should allow it atleast do something.
Maybe first thing I would do, after tighening cables, is put a jump pack on it and see if does more. or charger on high just fort few minutes. 6-10 amps high, not some monster.
Wondered that too. Click bait?
Old Feb 9, 2025 | 11:24 AM
nevil's Avatar
nevil
This poll makes no sense. You could have skipped wasting time on that and told us a lot more about the bike in question.
Old Feb 9, 2025 | 11:28 AM
702's Avatar
702
Maybe this a bot?
Old Feb 9, 2025 | 11:59 AM
Rounders's Avatar
Rounders
Originally Posted by 702
Maybe this a bot?
what is to gain?
