Adding auxiliary power block
Old May 23, 2025 | 06:40 PM
Troublesome's Avatar
Troublesome
Default Adding auxiliary power block
2022 Tri Glide ultra
So first, I'd like to find a spot with some room for a small auxiliary power/fuse block. There doesn't seem to be much room under either cover.
Looking at something like this, https://amzn.to/43yKO2F
Secondly, I'm thinking to run directly off the battery for power, but use a relay to keep the power switched. Does this sound like the best approach?
I'd need a bit of switched power for the relay, and don't want to pull this from the accessory plug.
It's a cam-bus, so can't come off the power switch, and that's clear up in front of the tank anyway.
Am I on the right track here?
Old May 23, 2025 | 06:47 PM
asa1199's Avatar
asa1199
What are you planning to use it for?
Old May 23, 2025 | 06:58 PM
Troublesome
Heated gear and charging port, and a couple of lights, are the current wiring projects. Nothing major.
Seems to me there was something else in the to-do list but it's not coming to me at this moment...
Old May 23, 2025 | 08:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You can power a charging port from one of the extra power connectors in the fairing.
I run heated gear wire direct from battery, it`s a short run.
Old May 24, 2025 | 07:33 AM
TracerBullet's Avatar
TracerBullet
Easternbeaver.com (my choice on my BMW)
centech
fuzeblock
don't go cheap. To easy to fry something
Old May 27, 2025 | 07:51 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Keep It Simple. Plug the heated gloves into the battery charging pigtail.
LN Nation
Audio Systems
Jan 3, 2024 03:12 PM
FDHOG
Pan America
Aug 17, 2021 07:47 PM
scarin
2014-2024 Touring Models
Apr 8, 2017 10:54 AM
No U Glider
Nov 29, 2016 08:30 PM
ECSTREET08
Jan 17, 2010 05:12 PM
