I have a 07 ultra and my cruz went out, the switch on the dash comes on but when you engage it cruz on the bar it didn't set the cruz. I want to change it out my self how hard is it to do
Try this procedure, I also have an 07 in which the cruise stop working. I discovered the roll off switch on the idle cable was bad. I disconnected for now to verifly it. going to dealer on thursday to replace cable
1. Hold cruise switch in the "set" position.
2. Turn the cruise "on"
3. Turn the main power switch on, the cruise light should initially come on then turn green, release the cruise switch the light will turn amber.
4. Push the cruise switch to "resume" the light should turn green, release the switch, the light should turn amber.
5. Roll the throttle "off", make sure you roll it off to activate the cutoff switch for the cruise, the light should turn green, release the throttle the light should turn amber.
6. Apply the front brake, the light should turn green, release it, the light should turn amber.
7. Apply the back brake, the light should turn green, hold the brake until the light turns amber, release the brake now, you should hear the cruise motor adjusting itself (taking ujp the slack).
Did you disconnect the rollback switch; it is located on the right side by the front of the tank. It has two connectors disconnect them and see if the tests work up till the throttle rollback check. If it does that is definitely the switch. Not sure how hard it is to change; the dealer is changing it under my extended warranty
