Hardwire Problem
Old Oct 12, 2011 | 09:03 PM
zspin's Avatar
zspin
4th Gear
Default Hardwire Problem
Hello all I'm needing help i want to hard wire my satellite radio on my 010 tri-glide. instructions say to tap into a wire that is turned on by the ignition key any ideas? Is there a way to tap into the fuse block or tap into the radio power I just want to make it look nice and be functional
Old Oct 12, 2011 | 09:16 PM
tombeving's Avatar
tombeving
I remove the outer faring and took a 12 volt DC power outlet and wired it into the leads on the cigarette lighter.
Old Oct 13, 2011 | 06:04 AM
zspin's Avatar
zspin
4th Gear
ahh good one never even thought of that thanks.
Old Oct 13, 2011 | 07:11 AM
UltraNutZ's Avatar
UltraNutZ
there is a free wire laying right behind the headlamp (orange/white) taped up on the same headlamp harness that is an accessory wire. there is also a ground right there but I never recommend you use a factory ground instead ground to something solid and metal (fairing bracket would be a good ground)
brad75raiders
Audio Systems
May 12, 2016 01:41 PM
Whiskersvtwin
Aug 20, 2012 11:49 AM
Jukebox
Jul 21, 2010 06:01 PM
Smitty0128
Jun 1, 2008 07:57 PM
Badbagger
Apr 28, 2008 02:00 PM
