turn sig. problem
Old Feb 28, 2012 | 12:06 PM
TATONKA 96's Avatar
TATONKA 96
Default turn sig. problem
I've got a 96 flstc,when I push the switch the lights come on but wont blink.some times they will blink once or twice but thats all(when riding)
when the eng is off (trying to track down the problem) they work fine.
I've changed bulbs,checked all of the grounds.Any help is greatly appreciated.
Old Feb 28, 2012 | 05:59 PM
Dallas 13's Avatar
Dallas 13
Take a look at your regulator. If it's not rectifying and filtering the AC completely it may affect operation of circuits. You may have enough voltage, but too much AC 'ripple' can disrupt things. When parked you have straight DC from the battery.
Old Feb 29, 2012 | 11:58 AM
TATONKA 96's Avatar
TATONKA 96
would'nt that affect the other lights as well?
I haven't noticed a problem with any other lights.
Old Feb 29, 2012 | 06:39 PM
Dallas 13's Avatar
Dallas 13
Other lights, while on steady, would not be as affected (by ripple). The flasher unit may be affected by the nature of how it works internally. It's a mechanical relay type timed switch. The ripple can affect how the relay operates.
Old Feb 29, 2012 | 07:27 PM
RANGER73's Avatar
RANGER73
Try to locate and replace the blinker relay first. Should be between the tanks, under the console.
Old Mar 1, 2012 | 12:30 PM
TATONKA 96's Avatar
TATONKA 96
Cool
thanks for all of the help,looked up the price for the turn signal modual J&P cycles got 'em for about $150.00. I really need to eliminate everything else first.
Old Mar 2, 2012 | 10:22 AM
UltraNutZ's Avatar
UltraNutZ
+1 on replacing the turn signal relay first. especially being this old..
Poa
Electrical/Lighting/Alarm
22
Mar 7, 2019 10:09 AM
BCGHD2016
2014-2024 Touring Models
Apr 15, 2018 10:12 PM
jf7689
EVO
Sep 24, 2015 05:19 AM
LowRider68
Jun 24, 2015 09:27 PM
Andjh123
Nov 7, 2009 09:44 PM
