Neutral Light Out
Old Mar 4, 2012 | 07:24 PM
Zooky's Avatar
Zooky
6th Gear
Default Neutral Light Out
Neutral light on soft-tail fails to illuminate. Any thoughts on the best way to determine cause (bulb, switch, wiring, etc.)?
All suggestions appreciated.
Old Mar 20, 2012 | 04:11 PM
grbrown's Avatar
grbrown
Start at the switch and work your way to the bulb, checking electrical connections along the way, also any breaks in the wire or insulation. If you havn't found anything by the time you get to the bulb, swap it for a known working one to see if that is the problem.
nchogfan
Dec 2, 2013 08:08 AM
warrconn
EVO
Sep 16, 2013 09:21 PM
hillbillyonahawg
Apr 25, 2012 05:11 PM
Zooky
Mar 5, 2012 07:54 AM
AIRHEAD
Apr 12, 2006 12:35 PM
