No right turn power.
Old Jun 29, 2014 | 06:09 PM
Guythunder's Avatar
Guythunder
Cool No right turn power.
I just installed a new set of run turn LED's on my 1991 Fat boy, After the installation I noticed that the right turn signal wasn't getting as bright as the left, So I went back in and did the wiring all over again and it still did the same thing not as bright on the right turn as the left is. I already have a load equalizer installed from the last set of LED's I had.
Well what has happened is I have lost all power to the right turn signal front and back, If it is a fuss where might it be located.?
Thanks
Old Jun 30, 2014 | 09:20 AM
grbrown's Avatar
grbrown
Fuses are not limited to just one side only! If your left indicators flash fine then you have an electrical problem on the right side. That could be as simple as a bad live connection or a bad ground connection.
Old Jun 30, 2014 | 09:53 AM
Guythunder's Avatar
Guythunder
Thanks I will be looking at it today for a bad ground or whatever I can find. I had to get away from it for awhile cause it was driving me crazy. Thanks for getting back to me.
Old Jun 30, 2014 | 09:56 AM
grbrown's Avatar
grbrown
Unfortunately electrical problems can be like that. Many minor problems like this are actually mechanical, that is they down to poor connections, corrosion, silly stuff like that. Disturb every connector on the right side, just to check they are clean and tight.
redskins32
Electrical/Lighting/Alarm
May 31, 2013 09:43 PM
littled62
May 27, 2012 07:16 AM
coop57
Mar 26, 2009 08:10 AM
Dr.Cool
May 10, 2007 11:13 PM
cartman18
Jul 18, 2006 02:14 AM
