S&S 510c or 509c
Old Jan 1, 2015 | 08:47 PM
kink04fxd's Avatar
kink04fxd
This is from S&S
http://www.sscycle.com/tech-info/cam...and-cam-specs/
Old Jan 3, 2015 | 10:43 PM
Road Star's Avatar
Road Star
So, I'm guessing, for a 98CI Touring bike it would be best to go with a 509 or 551 cam. Am I correct?
509: Designed as a bolt-in, high torque cam for 1999-'06 models. 180 psi cranking compression, no need for compression releases. For 88 CID engines with stock compression ratio. Idle-4500 rpm. Bolt-in torque.
** Since this is for 88CI, will it be OK for 98CI?
551: Designed for engines with 96 to 106 CID and 9:1 to 9:9 compression. This is a bolt-in cam set designed for stock or mildly modified touring bikes. 551 cams are not recommended for compression ratios of 10:1 or greater. Greatly improves low-end and midrange torque, strongest from idle-4000rpm.
***************** On another note...
Where do these cams come into play? When I would use either of these?
HP103: For the rider who really wants the most top end horsepower. Easily make 100 horses from a stock engine with S&S intake and exhaust. Ideal for lighter bikes and racing applications where getting the most horsepower from a stock engine is imperative.
MR103: These bolt in-cams are for the rider who wants more of everything without giving up low end torque for high rpm horsepower, or vice versa. More power all across the wide power band, from idle to red line.
Old Jan 4, 2015 | 08:09 AM
spdrcrjl's Avatar
spdrcrjl
This topic struck an interest to me. Like others here I am no cam/motor expert. I was looking for a cam upgrade for my 2007 96 cui Wideglide. I like the SE204 and the S&S 510 seems to be similar. Yes/No?
Old Jan 5, 2015 | 08:27 PM
Road Star's Avatar
Road Star
I'm still wondering about this ^^^
Old Jan 6, 2015 | 04:43 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Your heads will accept an S&S .570.........
Scott
Old Jan 9, 2015 | 08:41 AM
Road Star's Avatar
Road Star
bump...
Old Jan 9, 2015 | 10:18 AM
Hillsidecycle.com
Sponsor
98"/Andrews 37(or now 57) or a Wood 6 has been proven touring combo's for quite some time.
That, combined with even a Stage I Head, will run VERY well.
Scott
Houston_t
Milwaukee Eight (M8)
16
Feb 14, 2019 08:56 AM
marinepilot81
Jun 27, 2010 01:30 PM
electra glide
Feb 11, 2009 04:49 PM
atomicbeing
Mar 27, 2008 10:29 PM
