A Few q's after cam install
Old Nov 8, 2014 | 01:29 AM
ridedaddy's Avatar
ridedaddy
Default A Few q's after cam install
Spent the last couple days finding time to install a set of 57h andrews cams in my sg. I used s&s performance lifters and se tapered push rods. It all went pretty smooth, I did have to go to my local stealer for a rear cam gear shim kit though. I ended up needing the .140" shim rather than the stock .130" shim. I installed the se tapered pushrods at 3 turns rather than the 2.5 turns the directions called for after some reading here on the forums. I also used some red lock tight on the jam nuts. Now getting to my question, picking a set of lifters seems to be a crap shoot. Now matter how much research a guy does there is t really a clear answer, there is always someone somewhere that has had a bad experience with any lifter it seems like. So anyway I chose the s&s as I stated earlier and my concern is that when adjusting my pushrods it seemed like they bled down almost immediately. By the time I had my jam nut lock tighted and tightened down I could spin them. Is this becouse they were never pumped up to begin with? I soaked them in a bowl of oil overnight before installing them. I haven't actually started it yet becouse I had to go to work and hadn't got the exhaust back on yet but I did crank it over with the plugs out until the oil pressure light went off. Hopefully I can get it wrapped up tomorrow and Fire it up but the way the lifter bled down I wasn't expecting. Any thoughts?
Old Nov 8, 2014 | 07:46 AM
nhrider1's Avatar
nhrider1
Most likely the lifters were not primed. Just soaking them doesn't guarantee they will be primed.
S&S produces quality lifters, but I haven't used them...so I don't know if they are shipped primed or dry. Even if shipped primed, most manufacturers use a light oil to test them and that would probably bleed off quickly.
Be prepared for some noise on start-up. It can take a while for them to pump up.
Old Nov 8, 2014 | 07:50 AM
soft 02's Avatar
soft 02
My S&S were oily but not primed. My start up procedure is to put 8oz in the crank case, 1/4 quart in the cam chest and 2 quarts on the oil bag then crank it over with the fuse pulled for 5 seconds 3 times. When I fore it up for real there is no dry lifter chatter.
Old Nov 8, 2014 | 12:37 PM
ridedaddy's Avatar
ridedaddy
She fired up nicely and seems to run great. Alittle lifter chatter for 2 or three seconds but nothing major by any means. I think cranking it over with the plugs out to build oil pressure helped a lot. Lifter noise seems to be a lot less than it was stock. That's more than I can say for the throttle body/ breather noise the cams helped increase but I know that's the nature of the beast. So far im super happy. Took a small ride up the street and back seems to run strong, just waiting on a fuel map from fuelmoto and then I will be able to see what it's all about. Once again thanks to all the knowledge on this forum I knew exactly how to do the job and what to look for before even getting to tools out of the box. Cams, bearings, pullers, lifters, pushrods, gaskets, shims....around $650. The knowledge you guys share on a daily basis...... Priceless!!
Old Nov 8, 2014 | 02:00 PM
REPO1's Avatar
REPO1
Curious on the fuel map....what is the turn around time after you submit the request? Do they just email you this map?
Old Nov 8, 2014 | 02:29 PM
ridedaddy's Avatar
ridedaddy
Yes as a customer they offer unlimited support. I sent a detailed request and they should have a solid basest to me within a few days via email. Then I will load it to my winpv software and load it to my powervision. Alittle auto tuning and it should be real close.
Old Nov 8, 2014 | 07:38 PM
dforeid's Avatar
dforeid
Mine did the same thing... I ran mine 3 turns plus one flat. By the time I had them tightened up they spun freely. I just cranked it over several times with the plugs out until I had good oil pressure. No noise at start up. I went with Comp Cams 850 lifters though. $17 a piece from Jegs. They work great.
Old Nov 8, 2014 | 10:02 PM
slyedog's Avatar
slyedog
Did you put the heavier clutch spring in?
Old Nov 9, 2014 | 03:26 PM
ridedaddy's Avatar
ridedaddy
I haven't yet but I'm not against it. Once I get a map and a few miles on it I will see if it's needed. Have most guys found that they need it?
Old Nov 9, 2014 | 06:07 PM
slyedog's Avatar
slyedog
Its been known the stock spring will no longer have enough force and cause clutch slippage. Spring is cheap and other than a qt of fluid and primary gasket it is a good idea to just do it. I didn't even think twice about it. Did it same time I did my cams. Nice thing is the new big twins don't require a spring compressor. 6 10mm nuts and its on and off in no time. The lever pull isn't bad at all yet you can feel the response is significantly improved.
