Parts Required for Cam Change
Old Dec 13, 2014 | 01:52 AM
galaxyfe's Avatar
galaxyfe
Default Parts Required for Cam Change
So with a cam upgrade (2014 Softtail), what's the required parts list? Is there a mandatory list (like cam bearings, gasket kit, etc) and/or a recommended list (like different lifters, adjustable pushrods, etc) for SE cams? Thanks guys.
Old Dec 13, 2014 | 06:07 AM
Am4wag's Avatar
Am4wag
There's a lot of "while I'm in there(s)".
Old Dec 13, 2014 | 06:55 AM
Sandcrab's Avatar
Sandcrab
Default My List
Send me a PM with your email and I will send you my list in Excel with pt numbers. It is almost complete but contains parts that I saw were damaged but had nothing to do with a cam change, like the air cleaner cover seal. I took the costs from HD and also is the Woods TW222 cam & lifters that I am considering.
Old Dec 13, 2014 | 10:35 AM
dforeid's Avatar
dforeid
Just did my 2012 Ultra Limited:
Woods TW-222 cams from Fuel Moto - $380
Cam Gasket set (includes Timken inner bearings) from Fuel Moto - $59
Exhaust gaskets - came in above kit
SE TAPERED Adjustable Quick-Install pushrods from HD - $189
Comp Cams 850 lifters from Jegs - $79
Assembly lube from Jegs - $7
Spark Plugs (just because) from HD - $8
While you are in there, some do an Axtell bypass valve or baisley spring for your oil bypass valve (I didn't)
Old Dec 13, 2014 | 02:44 PM
robbyville's Avatar
robbyville
Similar to above, sorry I don't have the part numbers but:
Andrews 57h Cams - $199
S&S Quickee Pushrods - $179
S&S Hydraulic lifter - $104
Heartland Cam bearing installer/Puller - $95 (i"ll be selling mine after the change)
Torrington B168 bearings - $13
SE exhaust gaskets - $8
O-rings for oil pump and area - $3
Cam chest gasket - $9
SE Heavy duty clutch spring - $34
lifter Cover gaskets -$15
Locktite (because I don't have any) - $12
Assembly lube (Because KY won't work) - $9
Primary Formula and lube top off for clutch spring swap - $9
I think that's about it $680 or so all in, but I intend to sell my bearing tool afterwards. In my case I'm also combining the cam swap with my 5k mile service so add in oil, filter, etc.
As someone else mentioned, there's a lot of "since I'm already doing it stuff". In many cases that would be the lifters to replace the stock ones. Whether you really need to... everyone has an opinion based on the quality of the OEM stuff. some cams will allow you to use stock pushrods but more work involved since tank and rockers need to come off. The savings on going that route are not as substantial though as some may think since you then need to replace gaskets up top as well. Still it is a savings, but in my case someone rightfully told me "what if you make a mistake or there's some problem and you need to go in again", similarly the shape of my cams are different enough from stock that even though I could get by with stock pushrods it was insinuated that I would be better off with adjustable ones. Likewise some people re-use some gaskets but I figured why bother.
Old Dec 13, 2014 | 08:51 PM
FLSTC_Bob's Avatar
FLSTC_Bob
2010 Softail Cam Parts
Cam Andrews 48H or Other
You May Need One of the Following Cam Sprocket Shims
25729-06 0.100 inches
25731-06 0.110 inches
25734-06 0.120 inches
25736-06 0.130 inches
25737-06 0.140 inches
25738-06 0.150 inches
SE Tapered Push Rods 18404-08
SE Lifters 18572-07
Cam Bearings (2) Torrington B168 24018-10 9215
Gasket Kit, Cam Service 17045-99C
or
Cam Cover Gasket 25244-99A
Cam Plate O-Ring (2) 11301
Oil Pump O-Ring 11293
Exhaust Port Gaskets (2) 17048-98
Exhaust Clamps (2) 65296-95A
Spark plugs (2) 6R12 32362-04
Cam Lube 94971-09
Blue Loctite
Red Loctite
Oil and Oil Filter
Tools
HD Service Manual
Cam Bearing Puller 94144-09
Cam Bearing Installer 94107-09A
Push Rod Tube Installation and Removal Tool 94086-09
Cam Locking Tool 94076-09
ź” and 3/8” Socket Sets
3/8” Drive 6” and 12” Extensions
3/8” Drive ˝” Flex Socket. This is for the Exhaust Stud Nuts
Torque Wrench for in/lbs
Torque Wrench for ft/lbs
Bolt Cutters
Rubber Mallet
Screwdrivers
Snap Ring Pliers - There is only one snap ring
5/16” Open End Wrench
Two ˝” Open End Wrenchs
Torx Socket Set T15 to T40 (including T-27)
Allen Key Set 1/8” to 3/8”
Straight Edge Ruler
Feeler Gauge / Vernier Gauge
Lift - You have to rotate the rear wheel
Shop Rags
Brake Clean
Old Dec 13, 2014 | 09:21 PM
galaxyfe's Avatar
galaxyfe
You need to change cam bearings on a brand new engine?? Are they a different diameter or something?
Old Dec 13, 2014 | 09:36 PM
galaxyfe's Avatar
galaxyfe
Also, what's the benefit of the adjustable pushrods? From my research, pushrods are replaced just because you can cut the stock ones out without removing the top end and the rocker arms? Seems like a bit much, so I'm guessing there's other benefits.
Old Dec 13, 2014 | 09:38 PM
galaxyfe's Avatar
galaxyfe
And since we're here, I'll go ahead and ask the same about the lifters as well...including the solid lifter question...you guys go that route?
The is for all the help guys.
Old Dec 13, 2014 | 11:42 PM
FLSTC_Bob's Avatar
FLSTC_Bob
Cam Bearing and Lifter replacement is strictly optional.
Inspect and decide.
Adjustable Pushrods will save you time on labor, however replacement is optional for most cams (Camshafts with a different base circle can create the need for different length pushrods to compensate. Smaller than stock cam base circles are common in high lift cams).
