S&s or darkhorse
Old Feb 2, 2015 | 12:06 AM
Gater's Avatar
Gater
Default S&s or darkhorse
I am sure this has been talked about on this thread, but when I searched, nothing came up.
my question is weather to have my crank done at darhorse, or put a different crank. besides the welding the pin, has any one had an s&s crank slip?
I am not a hot rodder like i used to be, but I am going with gear drive on this next build. It will stay with the 103, a new exhaust and a good tune. nothing radical on this build.
I would like to here your opinions on crank shaft.
Old Feb 2, 2015 | 05:59 AM
mstng5point0's Avatar
mstng5point0
If you already have the size crank you want then darkhorse it. If you need anew one cause you want to go bigger then go S&S. IMO
Old Feb 2, 2015 | 06:21 AM
jmb79's Avatar
jmb79
Nothing wrong with either choice.
Old Feb 2, 2015 | 09:21 AM
Desertwndrr's Avatar
Desertwndrr
On my softail build, and now my touring build, I've purchased S&S units. It made sense to me after I weighed out all the costs associated with upgrading my stocker.
Old Feb 13, 2015 | 01:25 PM
tootal's Avatar
tootal
On my old Evo I used S&S and it worked great. On my twin cam I went with Darkhorse since I wasn't changing the stroke and mine had balance issues. They rebuilt my crank with new bearings, properly balanced and welded. Bike is amazingly smooth at 3000 rpm compared to what it was. As I rev it out it stays that way. Very happy with their work.
Old Feb 13, 2015 | 02:55 PM
djl's Avatar
djl
New crank for more stroke or work your crank, i.e., T/B/W, Darkhorse either way. JMHO.
Old Feb 15, 2015 | 11:26 AM
BVBOB's Avatar
BVBOB
On a reworked crank you still have what is reported to be a weak sprocket shaft. The S&S is reported to be stronger overall, as for price I would guess with shipping back and forth a new crank could be had for the same price as a rework and you will have your old crank to sell.
Old Feb 16, 2015 | 08:24 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Good bunch of folks over at Darkhorse.
Scott
Old Feb 16, 2015 | 04:15 PM
dirtdobber's Avatar
dirtdobber
When I did my 113 build I used Dark horse.
They did the case and crank.
If your staying with the stock stroke I would consider the S&S crank.
If going stroker, Darkhorse
Blue Tick
Engine Mechanical Topics
Sep 27, 2018 05:43 PM
monster715
17
Nov 18, 2014 08:46 PM
Neal Smith
Aug 20, 2012 01:36 AM
buford
Jul 27, 2012 11:55 AM
calin
Exhaust System Topics
16
Mar 27, 2010 09:02 AM
