Gear Driven Cams??
Old Feb 7, 2015 | 08:00 PM
galaxyfe's Avatar
galaxyfe
Default Gear Driven Cams??
Hey guys...so I searched, but couldn't piece this one together!
Gear driven cams in a late model 103...I know they come chain drive; is gear drive a mod that folks do to swap it over to that? Are there kits or something to make the swap? Was looking at them on S&S but couldn't really figure it out.
Is there a performance difference or just the benefit of getting rid of the chain drive? Do they whine?
Thanks for the info!
Old Feb 7, 2015 | 10:57 PM
bklynbob's Avatar
bklynbob
Bot really worth it on the newer hydraulic follower bikes. I wouldn't use it unless i had a 99-02 bike that have the forged cranks and Timken bearings.
Old Feb 7, 2015 | 11:52 PM
dynawg1's Avatar
dynawg1
Gear drive improves valve timing stability over chain drive due to eliminating the chains/tensioners which expand and compress slightly during the open and close cycle of the valves at high RPM.
You need to have .003" or less crankshaft runout to use gear drive, so bklynbob is correct that 99-02 motors with forged crank/Timken bearing are best suited for gear drive since the 03-up motors tend to have (much) higher runout.
The gear drive will make some noise but not obtrusive if runout is <.003" and they are setup with correct lash (.0005" - .001").
Old Feb 8, 2015 | 04:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Good advice/info.
Scott
yeoman71
Engine Mechanical Topics
15
Oct 28, 2014 10:47 AM
slammed05fatty
Apr 1, 2014 02:06 PM
Billy pep
Exhaust System Topics
May 15, 2013 09:39 AM
ZUTEDUFF
Dec 22, 2012 09:09 AM
18BKLR
Jul 18, 2010 07:30 AM
