Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Sorry I'm in the field this week guys. I do appreciate the help. I honestly think mixed up the exhaust and intake pushrods. I literally had no idea there was a difference. I bought a set of adjustables and will be installing them Friday. I see the difference between the exhaust and intake on these adjustable lol. Yet another lesson learned. Cherry
I'm going to install the new pushrods tomorrow when I get back. I'll keep you updated.
On screaming eagle adjustables is 2.5 turns past zero lash good or is there a better amount?
Others might throw things at me for this, but on the SE adjustables I've had better luck with 3 or even 3.25 turns out for cams/heads I've used. Not saying that you should duplicate ANYTHING that I do as a garage hack though...others on the forum do this stuff for a living, so keep an eye out for what they say.
Same here. Started at 2.5 with the SE tapered but ended up closer to 3.5 before it quieted down. Upper end sounds like a sewing machine now!
I have the FuelMoto adjustable pushrods and they say 4 turns and 2 flats. I'm hoping to finish the install this weekend and get some heat cycles in. The weather here is awesome!
The damn pushrod tubes are a pain in the *** trying to get the retainer clip in.
The more you do it, the easier it gets. Not sure how you're doing it, but a much better method than prying a screwdriver blade against a cooling fin is to use a medium-sized flat screwdriver and use it as a "ramp" from the front to let the clip slide down into place as the screwdriver pushes up on the retainer clip and down on the spring-loaded lower piece. Much easier to do than explain, but there are YouTube vids on this if you haven't tried this method.
I only bring this up because a lot of my "Shovel" brethren continue to break off cast cooling fins on their bikes because they pry against them with screwdrivers. :-)
I agree, I even called FuelMoto about that and they said to just use a screw driver and place it in the cooling fins and use it to push down that spring load part. I did that on two of them, I still have to get the other two on this weekend.
