Second oddity with the Fat Bob today.
My first oddity today was my 4 ways came on after I pushed the left turn signal button. Couldn't shut the 4 ways unless I disconnected the battery. I hasn't done it since. 2014 Fat Bob with 800 miles.
For those riders who frequently find themselves in riding conditions where the vehicle is subjected to prolonged idle conditions or traffic congestion, the motorcycle is equipped with an Engine Idle Temperature Management System (EITMS) to provide limited cooling of the rear cylinder.
When engine temperature reaches a predetermined point, the EITMS will turn off the rear cylinder fuel injector. Idle speed will be maintained, however the rear cylinder will become an "air pump" which will work to cool the engine.
EITMS will activate (rear cylinder will turn off) when all of the following conditions are met:
Engine temperature exceeds 284 °F 140 °C (all except configuration J and L) or 324 °F 162 °C (configuration J and L only)
Twist grip opening is at idle
Vehicle speed under 1 mph 2 km/h
Engine speed under 1200 rpm
EITMS will disable (rear cylinder will again fire) if any one of the following occurs:
Engine temperature falls below 275 °F 135 °C (all calibrations)
Twist grip opening is above idle
Vehicle speed exceeds 2 mph 3 km/h
Engine speed exceeds 1350 rpm
Clutch is released with vehicle in gear
When the engine is in EITMS operation, you may notice a difference in idle cadence. Additionally, there may be a unique exhaust odor. These are both considered to be normal conditions.
