Eitms
Old Jul 5, 2016 | 09:48 PM
rscott's Avatar
rscott
Default Eitms
I noticed when looking at my tune on computer that my EITMS on temp was 145 C and there is a EITMS off temp but it has no value My question is should there be a value there? Thanks
Old Jul 5, 2016 | 10:20 PM
Bone Doc's Avatar
Bone Doc
This is my understanding of what activates and deactivates EITMS.
EITMS will activate (rear cylinder will turn off) when all of the following conditions are met:
• Engine temperature exceeds 284°F / 140°C
• Vehicle speed under 1 mph / 2 km/h
• Throttle is at idle with engine speed under 1200 rpm
EITMS will disable (rear cylinder will again fire) if any one of the following occurs:
• Engine temperature falls below 275°F / 135°C
• Vehicle speed exceeds 2 mph / 3 km/h
• Throttle is opened with engine speed above 1350 rpm
• Clutch is released with vehicle in gear
Old Jul 6, 2016 | 07:53 AM
rusty289's Avatar
rusty289
From what I understand or have read the Rushmore bikes activate EITMS based on Ambient temperature as well.
I read it was 80şF, and I'd say the throttle and vehicle speed but not sure about engine temperature if that's still a factor.
I know mine comes on all the time, seems like every time I stop and the ambient is over 80.
Old Jul 6, 2016 | 11:40 AM
K Melancon's Avatar
K Melancon
Correct. Rushmores at 80° ambient and prior models to that it is based on engine temp
Snoviper's Avatar
Snoviper
6th Gear
I was wondering how many riders disable it even on hot days. I know I got my bike back from being serviced and they had disabled it, probably for the test ride. I am not sure how much hotter it runs without it on. Not sure if it is bad to disable it for everyday driving if the traffic is not that bad or your not stopped/idling for extended periods.
Old Jul 6, 2016 | 01:37 PM
rv7garage's Avatar
rv7garage
The EITMS on mine is always disabled. The whole concept seems hokey to me. But to each his own.
Old Jul 6, 2016 | 02:04 PM
hardheaded's Avatar
hardheaded
mines always off as well !
Old Jul 6, 2016 | 02:09 PM
qtrracer's Avatar
qtrracer
I leave mine on.
Old Jul 6, 2016 | 02:37 PM
iRider's Avatar
iRider
Mine is always on, there's plenty of heat to dissipate.
Old Jul 6, 2016 | 07:05 PM
josame's Avatar
josame
I left it on when I had my 2011 Road King, I leave it off on my 2016. There is no point for it to come on just because the air temp is 80, if the engine is cool/normal temp.
I don't care for the way it operates on the new bikes. should have left it the way it was on the pre-Rushmore bikes. Anyone know why they added the ambient temp sensor?
