Feuling Cams for 103 build, opinions?
Old Jul 22, 2015 | 07:40 AM
lionsm13's Avatar
lionsm13
Pretty happy w/my 525's for a bump on this thread.
They come on straight out of the box and go up into the 4's without much change.
Mild but keeps climbing w/very noticeble TQ.
Old Jul 22, 2015 | 06:45 PM
jackddg22's Avatar
jackddg22
Put the 525's in . Stock except Bassani road rage pipes, screaming egale a/c and Power Vision. No numbers, but this seems right to me. 6'th gear pulls from 200 on up, bike is just a lot nicer to ride. 2115 Low Rider.
Jack
Old Aug 3, 2015 | 07:44 PM
TOFTS's Avatar
TOFTS
i'm running the fueling 525 with the camchest kit not dynoed just download a generic tune. running in a 2014 twin cooled ultra... It kicks starts around 3000 all the way past 5500rpm need to get to a dyno or get a closer tune... using one from/for a twin cooled with a 255 cam.....Also running VH header CFR slip-on mufflers...SE air cleaner FYI
Old Jul 21, 2023 | 04:39 PM
speedjerm's Avatar
speedjerm
3rd Gear
Originally Posted by 2005 Roadking
Hi I have a 11 Roadglide Custom 103. Installed Feuling 543's with Fullsac x-pipe & baffles. Stock heads. Dynoed @ 92 hp & 95 torque. Installed Hammer Performace 107 kit & their lmpact level heads. 10.5 compression. Now 100 hp & 107 torque. Over 100 ft lb torque from 2650 to 5000 rpm.
I have a 2013 Electra Glide (interceptor) 103ci with Arlen ness big sucker, cfr full true dual exhaust, fueling 543 cams, power commander 6. After it was dyno tuned I’m at 93hp 105ft lbs. might upgrade a little more next winter to get a little more out of it.
Old Jul 21, 2023 | 07:03 PM
djl's Avatar
djl
Might want to check the date of the last post before posting, this thread is about 8 years old. I am not even sure why I opened it up?
A solid 103" Stage II (Stage I plus cam) should make 110-115 numbers; 93HP/105TQ is pretty typical of a Stage II 95" motor. There is a much room for improvement with your 103.
Don't bother with a reply. If you want help with where to go next with the 103, start a new thread.
blackjeep
Engine Mechanical Topics
38
Aug 9, 2020 07:10 AM
Clayton24
Dec 30, 2017 07:30 AM
Chad263
Jan 2, 2011 09:00 AM
simpkinst
Feb 12, 2009 02:45 PM
