Crankcase breather for Marelli EFI??
Old Jun 16, 2015 | 09:01 PM
timber0472's Avatar
timber0472
Default Crankcase breather for Marelli EFI??
Hey out there. Anyone have any ideas on making a crankcase breather for the older Touring Harleys with Marelli EFI? (Or where to get one?) I have the MM Ness big sucker and the MM doesn't allow for drilling and tapping like the delphi throttle body. I just helped my friend make one for his new Dyna and it worked pretty sweet, and totally hidden behind his Ness filter. If anyone has any suggestions I'm all ears.
This is sorta what we did to his bike...
Old Jun 16, 2015 | 10:42 PM
Ed Ramberger's Avatar
Ed Ramberger
Old Jun 17, 2015 | 07:34 AM
timber0472's Avatar
timber0472
Anyone used these?
timber0472's Avatar
timber0472
Originally Posted by Ed Ramberger
Sweet. Did you make that?
Old Jun 17, 2015 | 08:41 AM
Ed Ramberger
I came up with this design that used the spacers with the nipples rather than the metal tube that ran up and across the heads. My original design simply cut the metal tube and used it in place of the spacers with nipples. We then had the spacers made.
It was sold like this for several years by screamin eagle until they went to the cast assembly.
Old Jul 12, 2015 | 12:11 PM
JimmieJack's Avatar
JimmieJack
I was using something like the old SE set up but I kept getting oil leaking from around the washers next to the head. Anyway I want to do a set up like the one in the picture for the Dyna. Do you have the specifics on the mod. like what size fitting and the drill / tap required?
BTW - someone did a write up on a similar mod. with pictures etc. and I was looking for that when I ran across this post.
Jimmie
Old Jul 12, 2015 | 05:08 PM
timber0472's Avatar
timber0472
Jimmie
Yea the fitting was a 1/8" ntp. I believe the bit I used was a .0 bit thats something you may want to google. The tap was a 1/8 x 27 npt. It was pretty simple to do and works great.
Best of luck.
Old Jul 12, 2015 | 10:51 PM
JimmieJack's Avatar
JimmieJack
thanks
Jimmie
yobtaf103
Milwaukee Eight (M8)
Mar 21, 2019 03:18 PM
Stang951
Oct 26, 2014 10:27 AM
TattooBill
Apr 15, 2011 08:53 PM
old skool1983
Feb 16, 2011 05:59 PM
fxdx-fly-by
Jul 30, 2010 09:11 AM
