Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Oversize drilling is a pain, there really isn't enough meat there and you screw up gaskets and outer primary.
You only need 12-13 ft/lb on these fasteners. So if you go 2 diameters (about 8 coils) on a stainless helicoil then you should have more than enough strength.
A 0.5" length helicoil is fine and I have used shorter at times. If you have changed to stainless fasteners then watch galling of the stainless to stainless surface. A little bit of anti seize will prevent.
thanks guys !!! I took it apart and resealed the primary ,(clutch basket leak)
reassembled and pinched #7 screw on rotation !!,may have been bad from earlier owner,will rip down in the morning,unfortunitly I have a heli coil kit in my FL home,i used on my 07 cement mixer(HD),gotta fix ,hate leaks !!!!,so that's .05(1/2 in) do u guys know what size tap and drill,BILL
