Help me spitball possible engine work...
Old Sep 10, 2015 | 07:53 AM
Next In Line's Avatar
Next In Line
Originally Posted by rhuff
Haha.....dammit....how did you guys go from me wanting 100 HP and 110 TQ to go get a 124"?!
Honestly, I feel like if the 107" in my RK ever goes to **** on me, I'll stuff a 124 in that but I'd like to keep the Road Glide extremely dependable and dammit, 100/110 area.
Now don't get me wrong........I WANT a 124 in that bike, but most importantly I want it do be a good runner and not married to the builder if that makes any sense as I'm no mechanic and put on 10-15,000 miles a year.
Or should I just get the 124"
S&S Cycle T124LC (585 cams / dished pistons) will give you 10.2:1 compression ratio.
The higher the compression and more radical the cams are, the lower the mileage before it needs work no matter how big (CI) the engine is.
Old Sep 10, 2015 | 07:55 AM
Next In Line
Originally Posted by prodrag1320
130/140 out of a very mildly built 124" would be the way to go
Originally Posted by Hillsidecyclecom
Yep, easy to see 130/140 from a 124".
Scott
What are the numbers for a 124" Hot Set Up Kit using 640 cams @ 10.8:1? No head porting, using supplied gaskets.
Old Sep 10, 2015 | 08:36 AM
rhuff's Avatar
rhuff
Very true. My 107 has the 10.5 compression and I like it....wouldn't want anything higher. Honestly, the 124 LC has always had my eye.....
Old Sep 10, 2015 | 08:40 AM
grbrown's Avatar
grbrown
Talking
That's that then - are we all agreed?!
Old Sep 10, 2015 | 10:12 AM
Next In Line
Agreed.
Old Sep 10, 2015 | 10:21 AM
grbrown's Avatar
grbrown
Red face
Well, it's like this! Those of us with that performance level know we cheaped out and we wouldn't want you to do the same, then bust us for not telling ya to go the whole hog!
Old Sep 10, 2015 | 11:41 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
With their 66mm Throttle Hog and a good pipe along with the 1.650" exhaust valve they now use, we are seeing/hearing 140 square.
At/near 150/150 if headwork/compression is introduced.
Scott
Old Sep 10, 2015 | 12:16 PM
ntraindavefl's Avatar
ntraindavefl
If the op is looking for 110/100 there are a few bolt in cams that could do the trick, cheap money...
Old Sep 10, 2015 | 12:35 PM
soft 02's Avatar
soft 02
Cheaper to drop in a crate 124" w/ 585 cams instead of a bunch of small upgrades over a long period of time.
I did the 107" in stages and eventually ended up with the 124" and 585 cams. Wish I went straight to the 124" from the start. More power than I even need and very reliable. Kirby built mine and I couldnt be happier with the results!
Old Sep 10, 2015 | 01:51 PM
Next In Line
Cams are a gateway drug
