Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I may be doing this more out of boredom than reality of doing engine work while bike is still under MoCo warrantly until June 2017.....but....let's say I do this winter I'd go two ways: Big: either a 124 built from my cases or something more economical. The reality is when I do, I'll prob go big as my 03 is a 107 all bore and while I love it, the addiction set in....
Saying I go small, I'd be looking for probably 100 HP and 110 TQ. What options and specifics do you suggest? I prefer to spin my all bore 107 and feel the desire to do the same on this, but with a little less power, maybe a cam that comes on sooner than my Andrews 67 would be in order??
A well built 107" is capable of delivering 120+TQ/115+HP. So, if you would be happy with 110TQ/100HP, all you need to do is rebuild your 107"er with the right components.
My 107 is in my 03 RK. Looking for engine work on a 15 RGS. Also, I'm looking to keep costs down and not wanting to get into 115/115 and up area as I'm more inclined to do the bottom end at those numbers, hence why I'd just go big if i started to fiddle in that area of power.....looking to do a bit of a budget build that will get me in that ball park.
Cheaper to drop in a crate 124" w/ 585 cams instead of a bunch of small upgrades over a long period of time.
Yup - when my boat comes in that is my preferred route. I also have a 107" at present, although my numbers are a little lower than yours, so a mild 124" with the same 585 cam I currently have sounds just perfect!
130/140 out of a very mildly built 124" would be the way to go
Sounds right to me! I modified a Dyna some years ago and worked out what would be required to give a loaded dresser similar performance - and around 130/130 seemed to be a suitable fix!
Haha.....dammit....how did you guys go from me wanting 100 HP and 110 TQ to go get a 124"?!
Honestly, I feel like if the 107" in my RK ever goes to **** on me, I'll stuff a 124 in that but I'd like to keep the Road Glide extremely dependable and dammit, 100/110 area.
Now don't get me wrong........I WANT a 124 in that bike, but most importantly I want it do be a good runner and not married to the builder if that makes any sense as I'm no mechanic and put on 10-15,000 miles a year.
