Question about installing cam bearings in case
Old Sep 17, 2015 | 02:18 PM
martin10's Avatar
martin10
Default Question about installing cam bearings in case
Getting ready to change cams in a 103. In the service manual it says to measure the depth the bearings are pressed into the case. Is that really necessary? Haven't seen it mentioned in the two videos I watched. I have installed cams in two 88's but this is my first time on a late model. Thanks.
Old Sep 17, 2015 | 02:44 PM
Dan.1977P's Avatar
Dan.1977P
What does it hurt to spend the extra 30 seconds to measure it and put the new bearings in at the same depth?
Old Sep 17, 2015 | 05:10 PM
prodrag1320's Avatar
prodrag1320
as long as their under proud,your fine
Old Sep 17, 2015 | 05:27 PM
martin10's Avatar
martin10
Thanks. I didn't want to have to take the install tool apart numerous times to get to a specific depth.
Old Sep 17, 2015 | 06:47 PM
chief08's Avatar
chief08
install tool put's them to right depth
Old Sep 17, 2015 | 06:54 PM
Notgrownup's Avatar
Notgrownup
I tapped mine in with a seal driver until they were sat in.
Old Sep 17, 2015 | 09:40 PM
galaxyfe's Avatar
galaxyfe
You'll see the beveled edge of the case once you get it apart. If I recall, the bearings go in just past flush to the bottom of the beveled edge. Just tap it in until it's in that spot. It is fine!
Old Sep 18, 2015 | 06:26 AM
martin10's Avatar
martin10
Damn. I should have thought of that Chief. Pretty obvious now that I think about it. Cheers.
Old Sep 18, 2015 | 06:42 AM
prodrag1320
yup! I use a piece of delrin (plastic) to tap the bearings in,you can get it from McMaster carr.just machine the end to loosly fit in the bearing.remember to always install with bearing #`s facing out
poblete
Aug 28, 2017 08:53 PM
dforeid
Nov 2, 2014 10:59 PM
MOSTWANTED
Exhaust System Topics
Jul 20, 2013 07:52 PM
09B29
Nov 13, 2011 07:45 AM
AdrianVall
Jan 20, 2009 06:53 PM
