Bike slow to start
Old Nov 14, 2015 | 02:42 PM
deuce_streetbob's Avatar
deuce_streetbob
Default Bike slow to start
Looking for some guidance from the group. First off, 103, woods 222 cams, basanni road rage B1 pipe, high flow AC, power vision. For the most part, the bike once warmed up runs just fine, but where my issue is would be during startup. the bike will start, but i have to feather the gas to keep it running or it will cough and try to stall out. it does this until it gets to about 150 degrees temperature. does anyone know why it would do this? i have autotuned with the PV, but not professionally tuned. any ideas?
Old Nov 14, 2015 | 11:37 PM
Next In Line's Avatar
Next In Line
Sounds like the mapping is not correct for the idle/warm-up.
Google "Power Commander V Stalling at Idle".
Old Nov 18, 2015 | 07:39 AM
grbrown's Avatar
grbrown
Autotune is no substitute for a proper dyno tune IMHO. That will also get you in front of someone skilled in diagnosing running problems. So if your bike simply suffers from poor fuelling, or whatever, he will either be able to sort it out, or advise you on the problem. You may be surprised just how well your bike rides after it is done!
Old Nov 18, 2015 | 10:11 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The PCV is a good for ballpark tune but like Mr. Brown says no comparison.
If you do decide to get it tuned by a reputable tuner on a dyno, I'd love to see the results. I my self am thinking of getting a second bike with a103"er and going with the 222. I believe that cam in a stock 103 with pipes, a/c and a good tune should be capable of 115 tq and 107 hp. Might be wishful thinking but i think the numbers will add up. Thanx...
Subscribed.......
Old Nov 18, 2015 | 01:26 PM
Tat2u's Avatar
Tat2u
+3 to getting it on the dyno
It would be a good build if you could get 107hp with stock heads
Old Nov 18, 2015 | 02:03 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
It sounds like the low RPM/low pressure (high vacuum) area of your tune needs some attention, if the Minimum MAP settings were not changed from their defaults when Auto Tuning you will likely find some of the cells in the VE table were over-corrected causing a slight lean spot. This should not be difficult to get fixed up. If you need any assistance you are welcome to contact us.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Nov 19, 2015 | 12:36 PM
deuce_streetbob
Hey Jamie, is it still possible to somehow pull the tune file off the PV and send it to you guys to look at/possibly adjust? I bought the PV used, but got my unlock file from you guys about a year ago. How would this process work? And if possible, maybe a dummy's quick guide on how to do it?
Old Nov 19, 2015 | 12:38 PM
deuce_streetbob
btw, to answer others, the bike runs pretty darn good once it gets to operating temps. no issues at all. i DO know that a full professional tune would benefit me, and i would love to do one. only thing is, i have been eyeballing doing a 107 hopefully before the spring and i don't want to spend money on a tune only to have to do it again in 6-8 months.
soldierbot
General Topics/Tech Tips
Jun 3, 2017 10:08 AM
2mOOn
Sep 15, 2014 06:52 AM
2mOOn
Sep 8, 2014 07:25 PM
txphatboy
Sep 26, 2013 07:15 PM
whynotf75
May 18, 2013 11:57 AM
