Do I have a problem?
Old Feb 18, 2016 | 08:50 PM
Jlloyd62's Avatar
Jlloyd62
6th Gear
Default Do I have a problem?
So I may or may not have a problem I could just be overthinking this but I just pick my bike up after having the 103 Screaming eagle upgrade completed at my local dealership. I'm running in the garage home for about 20 minutes what's around I noticed that only one of my tailpipeS has heated up. Bike does not have true duals and the pipe not getting warm is the cross over. Put my hand behind it was blowing cool air with little velocity. So am I being a worrying Nancy or might I have a problem?
Any constructive suggestions will be greatly appreciated thanks
Old Feb 19, 2016 | 05:51 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Take it for a good ride then touch it...
Old Feb 19, 2016 | 05:57 AM
QC's Avatar
QC
Not unusual from what I've heard in here.
Old Feb 19, 2016 | 06:06 AM
Iceman24's Avatar
Iceman24
Did the bike feel/sound like it was running fine on the trek home...?? If it was running on single cyl, believe me, you'd know it.
Old Feb 19, 2016 | 06:33 AM
prodrag1320's Avatar
prodrag1320
is the bike running on both cylinders?
Old Feb 19, 2016 | 06:53 AM
jamesroadking's Avatar
jamesroadking
Why don't you figure this out yourself, it's real simple. Take the mufflers and the cross over pipe off and see for yourself how it works. Dah!
Old Feb 19, 2016 | 01:20 PM
baloot-boy's Avatar
baloot-boy
So you had a 103 upgrade and you drove it home. Did it ride like ****? I think you would know if you were riding on one cylinder.
Old Feb 19, 2016 | 01:38 PM
98hotrodfatboy
Comon fellas, i think this guy lloyd is totally new to Harleys. Newbie only had 8 posts and he did an upgrade at the stealership.... Be easy on him, K?
Lloyd, did it feel like out was spittin n sputterin and harley any power on the way home from the stealership or did it pull like a locomotive? If it's the latter, i would think your ok...
Old Feb 19, 2016 | 01:40 PM
Bodean46's Avatar
Bodean46
May just be a simple exhaust leak on rear cylinder. Check the torque on your exhaust bolts.
Old Feb 19, 2016 | 03:48 PM
Tedwilliams09's Avatar
Tedwilliams09
At idle the exhaust will take the path of least resistance.. Right side generally has less bends.. Less resistance.. At idle.. More noticeable exhaust... Run the rpms up and you will see it balance out
